zero budget project
ioaudio
vienna/austria
hello to everybody,
i´m quite new to this forum, i know a bit about soldering, but not too much about schematics and such;
collected some kind of "material" a couple of weeks, mostly out of garbage.
could´nt find any input transformer yet :)
thats what i´ve found so far :
an old dual record player (from inside)
http://groupdiy.twin-x.com/albums/userpics/10055/normal_PICT0014.JPG
and it´s schemos
http://groupdiy.twin-x.com/albums/userpics/10055/normal_PICT0011.JPG
and an old grundig tk 19 tape recorder (wheel) , no
schematics yet (from inside)
http://groupdiy.twin-x.com/albums/userpics/10055/normal_PICT0016.JPG
the grundig uses 1x ef 86, 1x ef 86, 1x ecc 81 and 1x ecl 86.
and i recently got a studiomaster 16-16-2 mixer, just got a foto from the mic pre section
http://groupdiy.twin-x.com/albums/userpics/10055/normal_PICT0004.JPG
now i know thats all not high end stuff, but maybe its parts all together combine to something usefull.
any suggestions?
:grin:
big pics :
dual inside
http://groupdiy.twin-x.com/albums/userpics/10055/PICT0014.JPG
dual schemo
http://groupdiy.twin-x.com/albums/userpics/10055/PICT0011.JPG
grundig tk 19
http://groupdiy.twin-x.com/albums/userpics/10055/PICT0016.JPG
studiomaster 16-16-2 mic pre
http://groupdiy.twin-x.com/albums/userpics/10055/PICT0004.JPG
thanks for your reply,
my first thought on the phono thing was to build some kind of summing amp.
it came along with a pair of loudspeakers, so the output is driven 4,5 ohm speaker, not line out...
my first try was to use as is, i took two 5 ohm/10 watt resistors(the big whit ones in the pic) as a load and a voltage divider (adjustable with that small pots) quite funny sounding on bass, but not linear at all.
i would use it to sum the 16 channels from the studiomaster console, bypassing it´s summing amp. and maybe the pultec inserted, nice idea :thumb:
any idea for the dual to use as a compressor?
could i use parts of the old grundig wheel for a micpre? (one channel of course).
thanks in advance and sorry for my confused english.
