kante1603 said:Realese........nice word,hahaha.........
Udo.
Hoo you realized it!! Jejjejejje
Udo.
Yes ;Djicama said:Hoo you realized it!! Jejjejejje
kante1603 said:Yes ;Djicama said:Hoo you realized it!! Jejjejejje
Rocinante said:Alright I give up. So I've read a good deal of the threads via the Meta thread regarding the circuit but I guess I just need a more specific answer. So I have signal. I have my 30 and -10. My Psu appears to be working fine. I am using the Hairball 25-0-25 at 30v to power my Phat Phet as well as an Edcor xs1100 with a Don Audio adapter for the output xfmr. Okay so I can trace the signal coming in and at the input pot am getting a good signal BUT at the next 27k resistor (I believe where it travels to next??) and right before bf245a it's gone. Nada. I get nothing also anywhere else. So is it safe to assume I just have a bad Fet? Is there somewhere else I can look? Reading this little guideline written by Mark Burnley where he gives a pretty awesome and detailed breakdown of tracing the 1176's signal path;
http://groupdiy.com/index.php?topic=4481.0
it feels like the Fet must be what's wrong.
Now considering that bf245a's are nearly extinct (at least in the states) I guess it's a pair of 1N5257's I am gonna need but before I go through the trouble of ordering them (then the damn 5 day wait for just two Fet's!!!) I was just wondering if there is anything else I can check first?
D
kante1603 said:Don't know if a roundbridge rectifier will do this job properly,it's normally used on a psu.
Best to follow the recommendations here and go for germanium or Schottky diodes like BAT85 etc.Have used them often in my compressor builds from JLM.,and they are less than 8 Euro cent a piece when bought as singles.
The shown meter is a standard B*******r type,so the same as mine.
Hope to have helped,
Udo.
Taken from Gustav's homepage:jicama said:So i need 8 diodes for 2 meters? but Im still confused how can I solder them before the meter ???
kante1603 said:Taken from Gustav's homepage:jicama said:So i need 8 diodes for 2 meters? but Im still confused how can I solder them before the meter ???
https://pcbgrinder.com/download/Data_Sheets/Bridge.jpg
Udo.
kante1603 said:Yes,with the correct diodes (germanium or Schottky) of course,
Udo.
They will definetely work,maybe even your round rectifier will.....somehow and at high levels.jicama said:I´ve been reading at the other post people used 4148 and worked, I´ll give it a try and post back.
Thanks Udo.
kante1603 said:They will definetely work,maybe even your round rectifier will.....somehow and at high levels.jicama said:I´ve been reading at the other post people used 4148 and worked, I´ll give it a try and post back.
Thanks Udo.
Germanium and Schottky do it better when it comes to low level readings and accuracy.
Udo.
Sorry that I can't help you in this case because I haven't built these guys (yet).jicama said:I'm only using 1 PSU to feed both boards and the 2 lamps from the meters I posted before which needs 6v to 12v,on the resistance before the lamps I put 360R to drop the V, do you think is why the regulators from the psu are super hot?
kante1603 said:Sorry that I can't help you in this case because I haven't built these guys (yet).jicama said:I'm only using 1 PSU to feed both boards and the 2 lamps from the meters I posted before which needs 6v to 12v,on the resistance before the lamps I put 360R to drop the V, do you think is why the regulators from the psu are super hot?
So I don't know what the expected power consumption is for one board,what kind of psu it is,the transformer specs etc.
I would start measuring the voltages as usual.
Then start to sort things out.If the psu is not on the main board start measuring output voltages from the naked psu.
Then only connect one(!) board,no lights for the meter attached.
Do it with both boards and see if something changes.
Then run them in parallel as you did before,but still without lights.
In case the vu meter lights are bulb tubes or normal lamps be aware that these are really power suckers.
I always swap them out for a nice led.
Regulators start getting hot under several circumstances,wether the circuits draw too much current,wrong input voltage/wrong transformer etc.
For everything else Gustav or builders who have done them should chime in to get some more detailled specs.
Udo.
