Analogguru,
I think that the other manufacturer might well have been Amek, since they used an audio fader for their "bolt-on" original supertrue (before 'supermove' and their later moving-fader supertrue) automation.
Here's the deal if you build your own hybrid: Among visiting engineers, nobody will like it.
If it's for you and nobody else to use, then that's okay I suppose, but bear in mind that resale will be zero.
Yes, I like moving faders, this week I'm finishing a project in Pro-Tools, and I'm using a 'Command-8' USB moving fader controller to do the fader automation, since I do agree that things can be input more swiftly and intuitively with a fader than with a mouse.
But to make something that works, then to be able to incorporate touch-sense, and have read/write handover is tricky.
Then trim of moving faders is a bitch. Flying faders NEVER got it to work correctly, the ONLY manufacturer who makes a REAL working system with real-time "hear-it-while-you-do-it" is SSL, and everybody hates those two (Ultimation and 9000 series) automation systems... and I'm fully inclined to agree.
If it's to be a learning experience then by all means go ahead, but if you're eager to make an easy-to-use system with ANY sort of real power, you really should probably just forget doing it yourself.
This is as complex as building your own car. -Sure, you COULD do it, but it wouldn't be as good as an off-the shelf one, even if you buy someone else's engine, a third-party transmission, and have all the glass custom made for you...
You'll end up with something significantly more expensive and MUCH less useful. -It may not look that way to you right now, but that's the truth.
And no offence intended to Analogguru, but nobody who I knew ever liked that system (assuming it was the same as the early AMEK supertrue... which is in fact possibly not the case). Certainly, of several of the MANY automation systems out there, Here's what I typically hear people say:
NECAM: how crap it was and how often it failed.
NECAM II: how often it failed.
NECAM 96: How can one company STILL make crap automation?
Flying faders: How easy and very good it is.
Melkuist: How limiting it was
Diskmix: See Melkuist
GML: How good it was
GML: How fussy/unreliable it was
GML: How bad it was (see a pattern here?)
SSL E/G VCA automation: how much people like it
SSL E/G series How bad it sounds (admittedly only ever heard from moving fader snobs)
SSL Ultimation: how irritating it is
SSL 9000: how overly complicated and confusing it is
Uptown: How good it is for the price
Supertrue: -How 'less-than-intuitive' it is... and why can't we get Flying Faders instead???
Keith
