UPDATE: HERE YOU CAN FIND ALL DOCS:http://twin-x.com/groupdiy/thumbnails.php?album=399I probably go for DOA's in the IO board, what parts should i leave out?
There are some resistors that are on the side of the DOA square.
In case of DOA, solder these parts from bottom. Forssels have very short pins for example.
Other issue with PCB, that I used to solder DOA's direct to board, and
holes are smaller than Harwyn pins from Farnell you probably going to use..
Possible to put them on opamp then solder over the pads, this way you can have opamps in socket.
I'm about to order caps and some other stuff, are there any particular type/brand caps that have proven to be the best sounding ones in the sontec?
Will WIMA's be a good choice for the poly's?
Yes, Wima's are just fine.
There came 2 PSU's boards with the kit, is it OK to use one PSU board for both channels?
Sure. If you building two separate units, use 2 power supply's.
Normally, one power supply going for one stereo set of PCB's unless
you mentioned two PS, IIRC there were 3 people who needed separate
power supplys...
