I have designed a new (more DIY friendly) PCB for Neumann W492. It is a good sounding equalizer that I selected to be part of my mixer project. I will publish all the documentation here when it is ready.
Electronics:
Schematic
http://docs.google.com/fileview?id=0B_XBYPfmG8pVMDkyMmRlNjEtZmQwMS00OTgwLWJkYzMtNWRmNGYyZTE1NTRm&hl=en
Parts list
http://docs.google.com/fileview?id=0B_XBYPfmG8pVNWUxZjBhNjYtYjI0Ny00YzYwLWFlZmYtMTZjZTU4ZjhlZmE4&hl=en
Wiring
http://docs.google.com/fileview?id=0B_XBYPfmG8pVN2QwNmY2MTEtM2ZjYS00MDM5LTk5YzItNmFjZDIzNGM0YWUw&hl=en
Component designations top
http://docs.google.com/fileview?id=0B_XBYPfmG8pVNTZjNmUzYmMtYWJhYS00YTAwLWEwZDQtYjVlZThlMDlkZmQ5&hl=en
Components values top
http://docs.google.com/fileview?id=0B_XBYPfmG8pVMDEzYmEzNzAtNDI2ZC00NjllLTlkNTctZjlmNzRiMGRmNzJh&hl=en
Component designations bottom
http://docs.google.com/fileview?id=0B_XBYPfmG8pVMWE5ZjQ3MWMtNjZmOS00NzJjLTgzYTgtOTQzYWQ5MTljYjEw&hl=en
Components values bottom
http://docs.google.com/fileview?id=0B_XBYPfmG8pVYjMwMTU3MzctNWEwMi00NTVhLTlhNTgtMjU3ZDUyYjZiMjgy&hl=en
Trimmer adjustment
http://docs.google.com/fileview?id=0B_XBYPfmG8pVM2YzYTFlZmMtYjY0OS00NDkyLTlhOWYtNjVlYmNmZTkwNGM0&hl=en
PCB (Sfernice potentiometers):
Copper top
http://docs.google.com/fileview?id=0B_XBYPfmG8pVMGVlYmQxNzEtOTJkOS00YmIxLTg3ODEtMjQyN2UzNTdhZDE5&hl=en
Copper bottom
http://docs.google.com/fileview?id=0B_XBYPfmG8pVN2UwNDMzMmYtZjAzNi00MWQ4LTgzYjEtZWJiMWNlZDYxYWE4&hl=en
PCB (Omeg potentiometers):
Copper top
http://docs.google.com/fileview?id=0B_XBYPfmG8pVYzFhZjc5ZmEtNTFhNS00MDE1LWIxMDMtODEyMGNhZDQ3Njgw&hl=en
Copper bottom
http://docs.google.com/fileview?id=0B_XBYPfmG8pVNGY3YjhiMzQtMDE2Yi00MjFmLThjZTgtMmJlM2UyNWJlMjM1&hl=en
Curves:
Filter 1 http://docs.google.com/fileview?id=0B_XBYPfmG8pVYWZjOGU4N2QtODE2YS00ZTgyLTkwMDEtMzIzN2Y4YWE0YjQx&hl=en
Filter 2 http://docs.google.com/fileview?id=0B_XBYPfmG8pVOTBkNTg5MDMtODZlMC00Mjc3LWE2ZGUtM2Y4NDIyZmJlMmEx&hl=en
Filter 3 http://docs.google.com/fileview?id=0B_XBYPfmG8pVYmZkYjhkZDQtOTQ1Mi00ODcyLTk1ZWItYmRjZjMxYmI4MmQ2&hl=en
Filter 4 http://docs.google.com/fileview?id=0B_XBYPfmG8pVMWI3Y2E3NTQtMDU0MS00Y2RlLThjMmUtN2ZiZGY5N2EwNDQy&hl=en
Mechanical:
Potentiometer assembly
http://docs.google.com/fileview?id=0B_XBYPfmG8pVMTg4OTRiYWItYWY5ZS00OGRjLWFkMzEtYjM4MWE0OTM3YmMz&hl=en
Some details:
- low shelving filter +/-15dB, 50-400 Hz
- presence/absence filter +/-15dB, 0,063-1 kHz
- presence/absence filter +/-15dB, 1-16 kHz
- high shelving filter +/-15dB, 3-10 kHz
- all filters can be switched individually in/out
- balanced input and output
Boards are available here:
http://www.groupdiy.com/index.php?topic=10776.0
Potentiometers and knobs:
http://www.audiomaintenance.com/acatalog/potentiometers_conductive_plastic.html
http://www.groupdiy.com/index.php?topic=345488#345488
If you have other sources of potentiometers and/or knobs, please let me know. I will add them here.
http://www.vishay.com/docs/51031/p11.pdf (P11 datasheet)
My other projects:
Studer 169 EQ
http://www.groupdiy.com/index.php?topic=33996.0
Neumann OA10 discrete op-amp
http://www.groupdiy.com/index.php?topic=34105.0
Balanced 12 input summing amplifier
http://www.groupdiy.com/index.php?topic=29082.0
Balancing/unbalancing amplifier
http://www.groupdiy.com/index.php?topic=29333.0
