triple-gang concentric potentiometer (where can I get some?)
pixeltarian
Active member
Minneapolis
is such a thing out there somewhere? anyone know? sorry if I'm posting in the wrong section. I just didn't think this fit in black market. not sure what section would be more appropriate.
I'm looking for dual gang and triple gang concentric pots. if anyone knows where I can source these in small quantities, I would love you forever. especially the triple gang as they seem to be devilishly hard to find.
I have a few used ones from a bunch of Eela/raindirk channelstrips.
IIRC 10 triple for eq (gain and freq), and 5 duals for stereo aux (gain and pan). I'd have to check for the resistancevalues.... The tapers are likely to be linear for the freq and panning, and log for gain, but I'd have to check to be sure.
Which values and tapers do you need ?
In case it's a match, you can have them for just the shippingcosts.
Rob Flinn said:
http://www.omeg.co.uk/
When I was dealing with them direct (5 years ago) the min order was 10 pieces.
Currently dealing with them right now, also,.. for some dual concentric triple-gangs, price is £11 each based on the minimum order of 10.
http://www.audiomaintenance.com/acatalog/potentiometers_carbon_20mm_diameter_concentric_shaft.html
http://www.audiomaintenance.com/acatalog/potentiometers_carbon_16mm_diameter_concentic_shaft.html
Peter Purpose put me on to the idea,.. you can take them apart and interchange the wafers of different values, from standard Omeg pots of the same kind. Good if you just need one or two :)
