Slenderchap
The ez760 project is now complete..... here are a pair of them;
Gustav will be producing the PCB's and if there is enough interest Dan (ddt) will be producing a version of the metalwork (in his own style).....
[The main reason for this feeler is to gauge the amount of interest so that Dan can manufacture cases at the same time as those for the ez1084 EQ in order for him to keep the cost down]
Almost all the parts are either "off the shelf" or can be substituted by off the shelf parts....... we will get the unusual parts into stock for those who want to make it exactly as shown. (except for the meter which is no longer manufactured..... but Hairball has a suitable alternative)
Here are the instructions;
http://www.audiomaintenance.com/downloads/ez760_colourbook.pdf
It works and sounds just like the item on which it is based.... a little better in fact
Put your requirements in this thread if you are interested in PCBs or CASES.
Edit:
PCBs from Gustav are found here;
http://www.groupdiy.com/index.php?topic=10776.0
Cases from ddt are foundhere;
http://www.groupdiy.com/index.php?topic=35422.msg500579#msg500579
Colin
Edit:
Colin
