Hello,
I picked up a Strasser/ Schoeps cm060 mic and psu, and can't find a lot of information about it. How can I tell if it has a close speech capsule, with the low roll off pattern? It sounds great, just a little anemic in the low end. I read that the Close Speech variants were recognizable from having a "0" at the end of the model. If so, is there a way to modify the circuit to eliminate this? Did they do this to the amp circuit or the capsule, or both?
Thanks for any info!
