Hey DIy family,
I know it sounds newbie but, how does insert (send and return) works in non connected mode?. I mean from tip you send and from ring it's returns, but I wonder when there is nothing pluged in to the socket - the tip is pluged directly to the ring??? How does this socket works and calls?
If i want to bring insert section from console back to the patchbay, should I use the patchbay with the same socket where tip connected to ring, when there is nothing pluged in?? Cause in other way there allways have to be cable connected or something. Do I need any special patchbay for that reason?
Tried to find out but don't know name of this socket and procedure.
Thanks a lot
Thanks a lot
