how about some screw holes for secure mounting?
also caps for ic power rails would be nice to be on the pcb. what opamps you plan to use? hmm, i'd like to build this eq at some point.
more ideas to chew on
there is very much wiring... is there a possibility to arrange the i/o pads next to each other? or maybe run io and power "bus" traces at the backend of the pcb so one could use simple jumpers between the pcbs to daisy chain them? in which case you could manufacture one big pcb and have cut lines between modules. one could then use the whole pcb without much wiring, or snap modules apart and use what ever needed;)
