Filter I/O board's swithes must be placed on top side and band's swithces to bottom side.
For now i have no but i'm thinking to order new batch.
Added front panel to first post.
Thank you.
The fpd file has quite some double drillings with small offsets for pots,just to let you know.
But thank you,I can derive a couple of info from there,whether for 1 ru or 500 series format.
Question on decoupling caps:We talked about them recently (100nF,mounted at bottom side).From the ic data sheet I see a recommendation to use two on each ic (one each from each rail to ground).Is that o.k. for you?
Now again for parts sourcing,
best,
Udo.
