V672X (Telefunken V672a in GDIY51X format)
[silent:arts]
Berlin, Germany
I would like to present you a new member in my German Legends family, the V672X
based on the Telefunken UNIVERSAL AMPLIFIER V672a,
with improved output driver and added mic-pre features,
switchable series resistance (input impedance) and
switchable feedback resistance (gain)
[ original schematic | original data-sheet ]
NOTE: the V672X is NOT API500 COMPATIBLE, a GDIY511 Rack is required
Documents:
V672X Schematic
V672X PCBs
V672X Parts List
Calibration Instructions
#V672X on Instagram
Full Kits are available in the White Market
[silent:arts] said:
Schematics, PCB overlays and parts list added to the first post
Excellent Volker!
May I ask a question:The parts list says that Ü1,Ü2 and Frontpanel "....are not included any kit....".
Will you offer them (I guess most of us don't have a good access to Haufe transformers,and the panels look really nice)?
Thank you in advance,
Udo.
Hi Udo,
changed that to "* not included in the parts kit".
I will offer full kits.
However, it is easier for me and my stock inventory software to have the transformers and front panels as separated items.
Some people might have the transformers anyway (or V672D cards with broken thick film IC),
and the front panel can be either in silver or black.
Kind regards
Volker
When I come out from under the pile of things I have to finish building, I'd be interested in metal work, boards, and transformers.
Phenomenal job as always.
Paul
Hello Volker,
about adjusting,C8 is for symmetry trim,right?
Are there any rules or recommendations how to set the fine gain and the filters?
Udo.
Hi Udo, yes C8 is the input symmetry trim.
For calibrating we use the original V672D Meßvorschrift  8)
For the V5672 and V672X I adapted it like followed:
(for all steps my generators Zout is set to 200R, and analyzer Zin to 600R)
S1 =  dB Gain: 62dB / R Gegenkopplung: 240K
S2 = LPF OFF / Tiefpass Überbrückt to left position (on)
S5 = dB Input: -20dB / R Eingang: 2k2
GAIN ADJ R26:
Generator = 1kHz -40dBu
Set R26 to measure +2dBu
HF ADJ R37:
Generator = 15kHz -40dBu
Set R37 to measure +2dBu
LF ADJ R29
Generator = 40Hz -40dBu
Set R29 to measure +2dBu
    307.7 KB
For C8 input symmetry you need a special cable.
(generators Zout is set to 200R, and analyzer Zin to 600R)
S1 =  dB Gain: 38dB / R Gegenkopplung: 5K6
Generator = 15 kHz -5dBu
Adjust C8 for lowest possible output
    51.2 KB
Thank you for the docs Volker!
Two kits received this afternoon,parts checking time now (most time-consuming thing,I look forward to assembly)  ;D
The kit looks very nice and professional,the frontpanels are awesome!
Best regards,
Udo.
Done!
Finished assembly and adjusting/trimming today,all went very well.An easy build,well prepared (Grayhills came with stopping pins set already!) and complete up to the last washer.
Haven´t heard too much,but what I heard was excellent sounding.
Did first tests with some music via (Bo´s) active D.I.s as well as some microphones I had here at home.
Sm57 was easy too bring up to a useful level at just speech,even an SM7b worked good enough when raising speech level.With a Cloudlifter the SM7b sounded very very nice.
CMC6+MK4 was fantastic.
Addendum:
Heard it with U87 and U87Ai on vocals today,as expected it sounded excellent.
I can only recommend building them.Not only is it easy to do -I built two in just one day-but the kit price is on the more lower side compared to other kits in this sound range (290 Euros+VAT).
A massive thank you to Volker for another great project!
Best regards,
Udo.
P.S.:As usual the pics of proof,here while CMRR-trimming:
Edit:Addendum added.
    344.7 KB
Hi Volker,
those are 4/40-thumbscrews,they're just temporary because a)we are in metric land and I had no fitting silver countersunk types here and b) they are usable without a screwdriver  ;D
They look very nice on black facias,I have them from Cemal ("sahib") for my TAC gear which make them look even better,hahaha......
Cheers and greets to Berlin,
Udo.
