Biasrocks said:Thanks for the pictures La2a, very cool.
Any chance you could take a picture of the Attack and Release pots?
Mark
here the pictures
cheers
Mark
ilfungo said:Hi guys
know if there is a layout of the original 1176?
I'd like to build one with PCBs as the original
kazper said:Anyone have the better scan of the schematics, the link is broken. If you can send them to the group emails that would be great!
finally getting around to this. want to be sure the 'jumper' everyone is refering to is Cx6...and the mod is to replace it with a 47k? Ive already swapped r46 to a 22k and the 130k on the ratio to 68k.
Neeno said:Ok guys, after comparing the various schematics (original 1176, rev A and Mako's rev A) I came across a bunch of values that should be the ones used on the real Blue Stripe. Of course those have not been checked with a real unit, so, please if you own an original rev A Blue Stripe check the values and report back !!!
I did this as an experiment, you don't need to change anything if you followed Mako's BOM, in fact his revision sounds really good as it is !
And well, Mako, thank you very much for the rev A !!!! A great board, an easy build, just lovely !
I've got the values comparing the Rev A schematic to the one used by Mako (Original 1176) which are the ones between parenthesis.
R6 = 2.2M (560k)
R7 = 2.2M (560k)
C6 = REMOVE (33pF across R16)
C6a = ADD 68pF across R7)
R11 = 9.1k suggested by Ed Anderson (10k)
R12 = 2.2k (1k)
R16 = 100k (47k)
R17 = 4.7k (8.2k)
C9 = 6.8uF (47uF)
R30 = 150k (120k)
C11 = 10pF (47pF)
Rx14 = REMOVE (820k)
Cx6 = JUMPER (6.8uF)
R76 = 10k (8.2k)
R54 = 1.2k (470r)
C27 = 0.012uF (0.022uF)
Ratio Board
R22 = 47k (56k)
R19 = 68k (130k) NOTE: If you're using the great Hairball PCBs R19 is marked as R8 on the documentation
R78 = 47k (NOT PRESENT) NOTE: R78 is marked as R10 on Hairball PCBs
R64 = 2.2k (1.2k)
LINE AMP MOD
This mod adds a resistor (3.9k) in series with a capacitor (1000pF) and it should be connected from the (-) of C9 to the junction of WHTRED - R32. Take a look at the picture.
