Svart
I'm not sure why anyone would use anything but a nice handy FET here.. Simple Nchannel and a 10k resistor is all that's needed. I have a couple out there in the world with this and they've worked for years.
Svart said:Simple Nchannel and a 10k resistor is all that's needed.
jdbakker said:peter purpose said:Is this the kind of thing to turn the old girl on at leisure?
With that cap to ground instead of to the emitter of Q1 it'll be more of a rude awakening (assuming the cap's empty at turn-on). Also if V1/V2 drop rapidly at turn-off Q1 BE might zener.
Otherwise... maybe. The TDK data sheet doesn't give enough information here (other than that the RC pin may source up to 1mA). The slew rate on the collector of Q1 looks awfully slow, and the CC6 may well not like that. Best case it might work, worst case it could go boom (literally).
A single OC-out comparator with some hysteresis is a safer (but more expensive) bet.
JDB.
Stick them in a bit of blu-tack and throw them at the cat?
Svart said:I'm not completely up to speed on my cockney.. translate please.
Dan Kennedy said:I also used a simple transistor turn-on circuit that keeps the converter off until the rack is near full supply, or it's initial surge will cause the regulators of the rack to current limit.
onlymeeee said:Dunno if that helps or confuses matters.
peter purpose said:onlymeeee said:Dunno if that helps or confuses matters.
??? Where's the booze?
peter purpose said:Svart said:I'm not completely up to speed on my cockney.. translate please.
;D Roughly translated as......
Am I on the right track Dan?
djn111 said:Hi,
Why not using a of the shelf solution like this one VLA106-15242
DJN
djn111 said:Hi,
I believe the VLA106-15242 can deliver 100mA, 24VDC, so with the current inrush limited to 90mA it should be oke.
DJN
onlymeeee said:What are we saying the module needs? 106mA ±10mA at 24V DC ?
Peter, was that 'scrub' circuit in ref to the one I'm using?
If so, I'm not using the RC pin to switch.
I'm using transistor as a constant current source.
Maybe I've got a small pcb somewhere you can have to have a 'play' with?
Or maybe a fully built one as a trade for one of those lovely red marconi knobs?
