Hi Ian,
Card is ready. I am preparing to launch a number of kits this week including this one. So I am a bit snowed under with preparing the documentation but I can send you one with the Black front panel/knobs.
However, here is the introductory info.
The card is for carrying out tests using an unbalanced source and measuring instrument.
The signal source may be from a generator or computer. A sine wave signal is recommended.
The measuring instrument could be a DVM, level meter, oscilloscope or computer.
If a computer is to be used it is recommended to use software from True Audio or similar.
http://www.trueaudio.com/rta_abt1.htm - the free version is sufficient to carry out the tests.
If a DVM is to be used it must be capable of measuring high frequency low level signals in order to carry out Symmetry and CMRR adjustments.
The inputs and outputs of the module under test remain connected to the rear connectors when the jig is inserted in the extender led. It is highly recommended that all connections are disconnected from the rack that relate to the module position under test. This includes multiway connections. This will eliminate the effects of loading by cable or external equipment.
There are special cases where these connections may be made and these are discussed later in the text.
The jig places a load of 600 ohms on the module output. This the normal load applied when testing professional audio equipment because it can create worst case output swing and THD conditions.
PHONO connectors are provided for connection to test equipment and/or computer. These are unbalanced connections and the two INPUT sockets are wired in parallel as are the OUTPUT sockets.
Top sockets are for the connection of a signal generator.
Bottom sockets are to the measuring equipment – DVM/oscilloscope/computer.
Additionally test points are provided for each of these lines.
A balanced standard jack plug allows for a balanced feed to be produced from the unbalanced PHONO input. This feeds the PHASE and CMRR test circuitry which is situated before the jack output and can therefore be used to test other equipment or systems.
Similarly, a balanced standard jack plug allows for an external balanced feed to be connected to the measuring equipment. "
