[quote author="mich"]the compressor now works - after i added R64 on the switch..... :green:
calibration goes well,but i have some dirt on the signal when compressing and even more with limiting.its not a lot but i think it should not be there.
when i have the out pot fully C.C.W (where it should be zero output) i can hear this distortion, and it increases as i turn up the input pot.
could it be a layout problem? (taking the negative input of A2 to ground eliminates it)[/quote]
Mine behave the same way. These things distort easily (part of their charm), but the more clockwise your rotary switch is, the less distortion appears to be present. So I'm thinking this is a fet anomaly.
PRR had something to say on the matter a while back. I'll see if I can find it.
PRR... "Because the FET sees the pre-limiting signal voltage, it overloads on strong signal. To make it work on typical line levels you have to attenuate the input, forcing a compromise with noise. It also is highly sensitive to FET parameters."
peter
