300$ IMHO is still a lot for such product... I could probably offer them for less than 100€ and considering
the DIY PSU parts all together can't go over 150€ per one dual rack... probably even much less than that.
Well sure, they can be made for less. If someone wants to offer a chassis kit/psu pcb combo, the price would come down significantly and I'd be all over that. OTOH, the cost and effort to build a one-off from a blank enclosure (if you don't have a metal shop) makes the A-Designs rack look pretty good.
Lunch boxes and their larger brethren are a little more complex than a box.
2-11 connectors have to be accommodated. Either by a pcb or inter panel.
Not saying it's rocket science, but a simple box it aint.
it doesnt matter if i use bc184c or bc184b, right?
184b has a lower minimal value for the small signal current gain than the 184c, 184c has higher maximal value than the 184b)
can i substitute the vcr2n with a vcr4n ?
(vcr2n has a max. drain-source resistance of 60ohm, the vcr4n of 600ohm)
