Kazper. Why are you going to all the bother trying to make an API face plate when you don't have an API lunch rack for it? Why not put it in a regular rack case. More roomy and options...
I'm thinking of doing just this - make a single rack space, Front Panel Express file, get EDAC connectors, or whatever, and just rack the 2 units. Only thing is the P/S. Anyone know what I need? Or maybe just buy the JLM powerstation, and that will most likely work for what I need.
Hi everybody.
I am trying to understand if I could use a 100uA amperometer on the 525 instead of the 200uA.
I thought I might just add a resistor in series to make the 100 uA work like a 200uA.
is this assumption correct? if so could someone suggest me a value for the resistor?
hi richie,
i haven't had time to really take a good look at this project yet, but here's my understanding of the following:
1) VCR2N transistor and socket
this is the vertical opamp i believe. One of the smaller boards square-ish boards with the 5 transistors on it. you do not necessarily need sockets for this board but it might be a good idea if you want to remove it later.
you could just add some buss wire and solder to the pads on the DOA board and then solder to the pads on the mother board for connection. look on the third page of the BOM it shows what parts go into this DOA marked "upright opamp".
2) all the caps that are in the pf range minus the 150pf ... mouser and digikey seem to not go that small.
haven't had a chance to check on these yet. :? edit: i just checked the BOM and the only pF value caps are 47pF and 150pF which are readily available in ceramic versions from both mouser and digikey.
3) and I don't understand what "LM391X meter driver IC if using the LED meter or 200uA FSD meter" means.
you'll need an LM391x series IC to do the meter driver duties. there is a meter driver board that Peter supplies with the set of PCBs (the one with the row of LED markings on the overlay). the LM391x IC goes on this board.
hope this helps.
-grant
yo - check it......
i've been e-mailing with David at Cinemag. i measured the 525 circuit board and sent him a crude but effective drawing showing dimensions allowed for the transformers. he had to go do a little measuring but he is positively recommending his CMOQ-3 for our 525 compressor kits. he does not have any drawings or datasheets for this model on his website yet. but he made up a one page .pdf of the mechanical dimensions and sent it to me. it shows overall dimensions of the CMOQ-3 to be 41.5mm x 33.27mm. the center-to-center distance between the mounting holes is not shown. i measured the space on the board to be 43mm x 37mm so it definitely looks like this trannie will fit on the board. it is unclear whether the board will have to be trimmed or modified (for the bobbin or the mounting screws) but i'd be fairly certain that this can be done with a minimum of effort and not much risk in terms of damaging the board.
i've already asked David if he minds if i post that drawing on this here forum. i doubt he will but it's best to check first. if he says OK, then i will post the drawing. but the july 4th holiday is coming up and i'm taking a few days off so getting this done for you guys may take up to a week.
i'm sure that Ed's edcor trannies will work fine and they are probably very cost effective. however, i will probably get the Cinemag's for my 525's. i did not check on pricing for these bad boys yet. the CMOQ-3 comes in two versions: the -3H and the -3L. i believe that the -3H is the high nickel version and the -3L is the "regular" nickel version but we'll find out from David. go to www.cinemag.dot.biz
