John, is my circuit in any way similar to the 553x designs you mention here?I've used truckloads of 553x to drive 600 ohm lines.
I made one headphone amp with a discrete push-pull stage hanging off a TL07x. It could comfortably drive loudspeakers until the 1A wall wart opens it's thermal fuse. I ended up adding a R in series with the charging rectifier in the PS so the rails would sag under heavy use and protect the wall wart.
