Spencerleehorton
Ah sorry just read above and it looks like we need in the range of 95H - 175H on the primaries.
My inductance meter only goes up to about 30H!!
i have an old one laying around somewhere but i think it's for EI100Is there a winding sheet!!!
Have gone for a 6N1P tube over the 5963 or the 12AU7 as it’s better on bottom end.
лол6nip
Thanks for the info CJ!6N1P runs at about 160 volts and combining the two sections in parallel there is 8 ma.
160/.008 =20k
Check your primary inductance at 20 Hz and 20 v rms.
300 henries will load the tube at about 40k which will give you great bass response.
Measure your primary current with the secondary open at 20 Hz and 20 v.
If you are at 1 ma or below then you should have made in the shade with KoolAid.
