Sorry, forgot to mention. It was at 20Hz...At what frequency did you measure the reactance? Remember good old steel lams have inductance which actually increases at low frequencies so it may be OK down to 20Hz.
About 72mm x 64mm and 28mm stack height.XL= 10/0.00135=7407 ohms at 20 hz and 10 v
7407/6.28=1180
1180/20= 60 Henries
Z ratio is 2200/200 = 11:1
Voltage Ratio = root 11 = 3.3:1
should work ,
what are the dimensions of the core?
If the cathode resistor is not bypassed then bypassing it will increase the gain a bit.Is there a way to get a bit more gain out of this di using the 6N1P?
If the 470uF is already across the 220R then it is already fully bypassed. No more gain to be had I am afraid.So bypass the 220R and 470uf cap?
What are the chances of disassembling Cinemag OT lams varnished after the core was stacked? I have one with 50Ni/50Fe lams having shorted primary, the other has butt stacked iron core with the same windings but i prefer 50Ni sound for this project.Yes on the caps and you can disconnect the pot on the output if you have one, and do away with the two 330 resistors.
Murdock that core is bigger than the one I use so you should be all set. If you want more bass you could crack the I bars off and remove the paper gap but you have to clean the surfaces before reassembly otherwise you end up worse off than if you left it alone.
it is about spacecraft program in 1960s. There even were children toys named after spacecraftshopefully not a nuclear sunrise because i believe there is a rocket printed on that tube
i would stick with toroidal, as this made the biggest difference in noise to my buildDoes this seem like a decent PT candidate for this project?
https://edcorusa.com/collections/tube-power-transformers/products/xpwr083a-200v-40ma-8v-1-5a
Thx for answer. Yep you're right about shipping cost. I don't know if other members are based in Japan. I'll come black to you asap. Thx a lot.Shipping is the same price as the transformer, (80 US)
Buy many and become distributorThx for answer. Yep you're right about shipping cost. I don't know if other members are based in Japan. I'll come black to you asap. Thx a lot.
Haha yes indeed. But unfortunately I have no time for this.Buy many and become distributor*not financial advice*
