[quote author="playboss"]http://www.analog.com/en/prod/0,2877,AD9511,00.html[/quote]
Why?
The AD9511 is a nice part, but suggesting its application in DIY audio is a bit far-fetched. First, the jitter mentioned in the data sheet is measured by integrating the phase noise over 12kHz-20MHz, which is commonly used for (optical) communications links. For audio one would be interested in jitter from phase noise between ~10Hz-10kHz, which may well be more than the 12kHz-20MHz due to 1/f (and 1/f^2) noise. Second, I find it hard to believe that a regular buffer/driver with proper supply decoupling has more jitter than this part. Finally, who in DIY-land is going to solder a 48-LFCSP package?
[Now, the AD9511 does have a rather low noise divider. This might be useful if you had a low noise XO at a multiple of your ADC/DAC MCLK. This is quite uncommon, as higher frequency XOs have more phase noise (->jitter) than an XO at MCLK would have. Jitter on BCK/LRCK is moot, as it is easily removed with either a latch or a DFF clocked @ MCLK]
http://www.diyaudio.com/forums/showthread.php?s=&threadid=54023[/quote]
Ah yes, the thread where one forum member attributes over an order of magnitude higher jitter to plain gates than the rest of the world has found.
[quote author="TobWen"]Without using AD9511, is this design okay? It's asynchron, I think.
[/quote]
Broken image link, can't tell much from it.
JDB.
