[quote author="mhelin"]Now what kind of clocking scheme you have to use / is the best or the simpliest one with the 4 x Cirrus A/D's and the AL1401AG ("green" part no)?[/quote]
For maximum simplicity all you need is a nice, stable crystal oscillator. Feed one of the CS5381s this clock and set it to master mode, no external dividers needed. Set all other '5381s to slave mode, and you're all set.
[quote author="mhelin"]How about if you want to use an external WDCK? You'll need a PLL then, or could use the AL1402 (OptoRec) as a PLL, or S/PDIF receiver (CS8412 or never part), right? Regarding the jitter which is then better as a PLL the S/PDIF receiver or the OptoRec?[/quote]
That's where it starts getting hairy. You have three options:
- use the OptoRec, with horrible jitter performance (~1.5ns)
- if you can use AES/EBU sync instead of WC, use a CS841x or an SRC4392 (~100ps jitter)
- if you feel like spending a lot of time, design your own PLL, preferably with a VCXO. Depending on your RF-fu and your PLL-fu, jitter will be between ~100ps and ~10ps.
We've discussed jitter and locking recently in the
Word Clock generator and
Portable HDD recorder threads.
[quote author="Rochey"][quote author="jdbakker"]The disadvantage is that [the AL1401A] only supports a 64Fs BCLK, so if you want to use a converter like the TI PCM4202 which wants a BCLK of 128Fs in single-rate mode (which is all that you can use over ADAT without S/MUX), you'll need a CPLD between the ADC and transmitter to re-shuffle the bitstream.[/quote]
Damn, I handn't noticed that before...[/quote]
It might work. TI doesn't actually say that a 64Fs BCLK is verboten:
[quote author="The PCM4202 data sheet, page 9"]
The BCK rate is typically equal to 128fS in Single Rate sampling mode, and 64fS in Dual or Quad Rate sampling modes. Although other BCK clock rates are possible, they are not recommended as a result if potential clock phase sensitivity issues, which can degrade the dynamic performance of the PCM4202.[/quote]
It doesn't quite say that it won't work, but (in my reading) it rather recommends against it. If only we knew someone within TI audio to clear up this ambiguity...
JDB.
[and for Plan B, you could just put a SRC between the PCM4202 and the AL1401A. IIRC, the SRC419x does support 64Fs out. Overkill for a commercial product, but a lot less headaches for DIY]
