Svart
Read the review on that page. The single ADAT lightpipe is an output only. Only good for an A/D.
Svart said:Read the review on that page. The single ADAT lightpipe is an output only. Only good for an A/D.
Not much really.... I haven't seen it but it would probably take about 5 min to figure it out.Whoops said:Joe used the SM Pro Audio ADAT Lightpipe Output for PR8MKII card
http://www.zzounds.com/item--STOADAT
How hard would it be to do using this board?
stickjam said:babyhead said:I remember one of the heavier cats around here who dropped the octapre adat card into his preamp box.
This could save years...
Any idea who the heavy cat is that used an Octopre ADAT card? Anyone have service info on that box to infer the pinout, power and signal levels on the two ribbon cables that feed this thing?
Sure would be nice thing to have on the back panel of the 8-channel 1290 project I have on my radar!
-Bob
Skylar said:These are pin-compatible with the 5393...a much better converter. This chip is in the RME ADI-8DS and other stuff I'm sure.
The 5393 is superior in specs to the 5392, which is what the Apogee AD8000 and maybe Rosetta use.
http://www.asahi-kasei.co.jp/akm/en/product/ak5393/ak5393_f04e.pdf
You could upgrade to this chip with some careful SMD rework.
Skylar said:I have an OctoPre with ADAT card.
I just took the cover off...
That's it for me tonight fellas...more later.
gang of elk said:another option..
http://www.smproaudio.com/produkte/adda-konverter/a08-analog-adat-wandler.html
looks like the same card discussed earlier in this thread but now in a box w 8 analog inputs. at $50 more than the raw card i wonder what's going on, if anything, before the A/D conversion..
With a max dynamic range of 98dB, I would consider this a consumer-level converter.
Then if you want to swap the converters to the 5393, you'll be that much closer.
mitsos said:Is it possible to "fix" this part of the card and make a killer A/D or are we talking major modification?
