nothing i just was searching for the lm311 and came across this ic and remembered sentences from that video.I don't even know what you are trying to do or accomplish, a current source at the emitters works as a constant current source to bias the differential pair, adding a current mirror at the collectors serves as an active load and balances the currents at the collectors, this current mirror replaces the collector resistors, but what you seem to attempt to be doing: adding a single current source at the collectors along with the colector resistors is pointless, and even might be detrimental, why or what are you trying to accomplish with this? an alternative way to what? what is better than the regular way? Seriously, again, I don't want to be rude, but you are just guessing without a compass, I advice you to go back to the basics, you can waste a lot of time just throwing around random punches or you can read, learn, and experiment.
since the long tail often contains a current mirror, would the lm334 full fill that job?
Apart from the Make Noise STO VCO, Make Noise Maths and a VCA by frequency central everything else is made by me and it looks commercial.I don't even know what you are trying to do or accomplish, a current source at the emitters works as a constant current source to bias the differential pair, adding a current mirror at the collectors serves as an active load and balances the currents at the collectors, this current mirror replaces the collector resistors, but what you seem to attempt to be doing: adding a single current source at the collectors along with the colector resistors is pointless, and even might be detrimental, why or what are you trying to accomplish with this? an alternative way to what? what is better than the regular way? Seriously, again, I don't want to be rude, but you are just guessing without a compass, I advice you to go back to the basics, you can waste a lot of time just throwing around random punches or you can read, learn, and experiment.
that's what the datasheet shows, something similar.No, a current source is not a current mirror. The LM334 could replace the single transistor connected to the emitters of the long-tail pair.
No, its not something similar, a current mirror is not the same as a simple current source. A current mirror 'mirrors' the current from one transistor to the other.that's what the datasheet shows, something similar.
you must have understood me wrong or i gave the wrong impressing.No, its not something similar, a current mirror is not the same as a simple current source. A current mirror 'mirrors' the current from one transistor to the other.
We are honestly trying to give you good advice, but you refuse to take it, you just want to guess around and expect us to give feedback on you ideas, which have no basis, after repeatedly telling you that you need to study the circuits. JR, Abbey, NewMarket, myself and others have told you this several times. We are happy to help, but if you are not willing to put in the effort and actually study and take the advice we offer, then there is no point.
I get that you are excited, and that you are learning. But you do not know the basics and you are guessing, its ok to guess, for a while, not every time.
I'm busy with electronics for the past 13/14 years, off and on, i started to use a simulator some 3 months ago.No, its not something similar, a current mirror is not the same as a simple current source. A current mirror 'mirrors' the current from one transistor to the other.
It doesn't matter, you don't need a current sink in the collectors, you need a current mirror.you must have understood me wrong or i gave the wrong impressing.
the datasheet shows a ramp generator and CCaudle might be right, that you can use it a current sink.
Constantly trying to improve the tings i made in the past, desoldering from a pcb is not a fun job, removing the part is one thing, getting a new in is another thing.
logic circuit on a breadboad work (somewhat), but analog stuff. prety hard to get resistors, trannies, ceramic on them without bending legs.
i have these cheaper breadboards and a cheap multi meter for now.
This summer i wanna do something aside from electronics.
hehe, like i said, i found the element (component) by accident and/or it would it be usefull.You
I don't even know what you are trying to do or accomplish, ...
You
Yes it works without a current mirror because you have resistors, that is exactly what I said to you, the current mirror replaces the resistors. The current mirror is an active load, that is the whole point, you either have the resistors or the current mirrors, not both. You just showed the input stage, now you are showing a complete circuit, a differential pair alone can be used with current mirror or resistors, not both. The current mirror provides larger gain whilst balancing the collector currents and reducing distortion, it also converts a differential output to a single ended output.View attachment 94044
alternative Long tail simulation
in the end, after completing a routing task, i toke to time and did a try in the simulator.
it toke a while to dial in the resistors.
apparently it works without a current mirror.
but check out above the current sink transistor.
page 4 of Robert Pease's book: experts have no monopoly on good advice.
Pointing at himself.
I'm pretty sure you need the resistors, to have the swings on both legs separated.
The long tail i have been working (a long time) shows +/-1mA apart from the control voltage circuit.
You can get the Art of Electronics 2nd edition, it ia also great to learn and a lot cheaperi choose the current mirror.
I'll buy the series of Robert Pease so far reading, but not really the info i'm searching for, lots' of old ic's, than the last: The Art of Electronics 3rd Edition 130€!
i don't buy online, accept to the accounts i already, that is mouser and 1 or 2 small local shops.You can get the Art of Electronics 2nd edition, it ia also great to learn and a lot cheaper
PS. you can buy the international edition for a very low price
Well, since the 80s up to 2015, it was the only edition available, most of us learned from that version, it is very different from the 3rd edition which is not only updated but also covers different topics, I have both and I like both. I would say that for your needs it is perfect.i don't buy online, accept to the accounts i already, that is mouser and 1 or 2 small local shops.
the internet after a few decades is kinda old fashioned, obsolete is some kind of way (Facebook and CO and it's apps aren't your friend).
I buy what the local physical shops sells me, i provide a ISBN and they get it for me.
I'm mostly interested in (mos)FETs, transistors, inductors.
What does the 2nd edition have to offer?
