moamps
Hmm....P = I² / R or P = R² / i or P = V · I....
What about?Hmm.
What about?
i got those from professor Aaron Lanterman and it did work when i tried them.
or maybe i should multply, but it did work.
Either Pr A Lanterman is a loony or (more likely) you have transcripted them wrong.What about?
i got Ohm's law aswel power covered, but not the others or when to apply them.
calculating a frequency
1/(2 x PI · C · R) also works.
maybe they should open a threat with the Math formulas + drawings and when to use them and make it sticky.
than some circuit are tricky, like the Urei 1176 with parallel capacitors, transistors on different levels.
well, i might have switch the operators.You should probably send him apologies
Its only possible that you got the correct result using the formulas you posted if voltage, current and resistance are all equal to one, otherwise, sorry, but no, its not possible.well, i might have switch the operators.
But it turned out the same result if as using the classic formula i learned at school
P = V x I, without knowing the voltage (witch in that example case i did and could check it) and only using the resistor and current value.
i do have a A4 sized note block around where i write findings, but ...
Do you ever admit mistakes? Seems like you just change the subject every time someone is confused by what the heckin heck you are trying to say. Plenty of us are willing to help you...but please dont make it harder than it needs to be.well, i might have switch the operators.
i did?Well you have implied that he is an idiot.
Ya, a 4 channel MDO scope with spectrum analyzer would help a lot, but given that cost more than 10.000€, i probably never get one.I think there is something definitely odd, his entire story, the way he answers with unsolicited out of topic comments, etc... But perhaps we are being a bit harsh, he is not hurting anyone and he is not rude, yes, he really doesn't know the most basic stuff, he always has excuses and doesn't seem to follow advice, but he is only posting his stuff. Now that we are aware of this, perhaps we could just accept it and offer him advice, if he desires to take it, fine, if not, someone else might read it and get something out of it.
I really don't have a problem with him, I wish he would listen rather than just counter with some random stuff, but everyone here is a bit crazy.
TBH, there is far worse stuff in the Brewery
I dont follow anything you say, but yeah, MDOs are greatYa, a 4 channel MDO scope with spectrum analyzer would help a lot, but given that cost more than 10.000€, i probably never get one.
more or lesss had to eat less to get a tektronix 2212 used and i was happy to see the invisible.
Ya, a 4 channel MDO scope with spectrum analyzer would help a lot, ...
i take all the input.It is fascinating that you even know about 4 channel MDO oscilloscopes without knowing Ohm's law.
But such is life. I learned Maxwell's equations long before I was able to buy my first analog oscilloscope.
My opinion is that what the participants here are actually asking of you is that you don’t ask questions whose answers you don’t really even want to hear, let alone think about or adopt. In this way, you belittle them and waste their time. There may be other members who will not receive help because of this, which they would appreciate. You should think about it.
You accredited statements to him that are simply incorrect. So - in a spirit of constructive engagement - I suggest that you go back and edit your post to be correct. It's easy enough and would put things right on that front.i did?
Okay. But it's plainly odd that you contact a professor to ascertain the most basic of equations. Then quote them incorrectly hereI'm very well respect this man and that he takes time to respond.
i can't find the messages anymore.
Hardly extreme. Switching operators completely invalidates the equation. If you have P=IV and Ohm's Law then it's trivial to get the other equations correct.Like i said, i might have switched the operators and should have taken written notes at the time.
stop being extreme
