scott2000
ruairioflaherty said:Next up digital stair steps…
Lollipop "POP" bud um bum bum
abbey road d enfer said:These certain circumstances are when the internal clock is incredibly poorly designed; it's not likely to happen in real life, except if the internal clock is defective. This is clearly a case of degraded performance, which should not be the basis for generalization.
Grimm have to find an argument for selling their master clocks.
To be fair it didn't go THAT far off the rails, but yeah I don't quite get why many people have such strong feelings about converters...ruairioflaherty said:Why do converter and clocking threads always go off the rails so quickly? Next up digital stair steps…
You may be onto something there; indeed, some recent research has shown audibility of pre-ringing of LP filters.living sounds said:To my ears these sound more natural and musical than more expensive, much more recent ones I've tried. Probably due to the linear phase filters implimented in more recent filters, those can really ruin a signal.
There is less evidence to support that.There are those who see the root of the problem in S-D-algorithms.
bluebird said:But see, that's not a way to judge a converter. There are so many variables impedance wise The input impedance of the powered speaker and the A/D will be different. Could be a little, could be a lot. A DI Box will be sensitive to that. AND the output of the DI is WAY different than the output of the D/A. If your doing A/B tests make sure your comparing apples to apples a half DB difference in level and that throws the whole test off.
abbey road d enfer said:There is less evidence to support that.
john12ax7 said:Interesting about the Avid converters, as I've almost universally heard that the new ones were better.
If you were referring to 1-bit Sigma-Delta, yes they put a lot of demand on everything. That's why multibit Sigma-Delta have completely replaced them, as far as I know.living sounds said:Well, there are good reasons why most quality converter chips today provide a mix of multibit and S-D technology. S-D also puts higher demands on the surrounding circuitry, especially the clocking.
It is possible, I have no experience with them. SAR puts even more demand on every part of the circuit and R2R puts more demand on your wallet; as mentioned on one of the articles, they may offer better performance because they are better built, just because they are inherently expensive.To my ears DACs based on the highest quality R2R chips or ADCs based on discrete SAR implimentations sound more natural and musical than any S-D converters I have listened to so far.
I don't think there's anything in the algos dedicated to the elimination of spurious. Most spurious are due to defects in the analog path of both the signal and the clock. Improvements in chip design and manufacturing are probably responsible for it.Interestingly, the old converters I am currently using produce spurious tones at a low level (low enough not to be bothered by them). Maybe it's the algorithms in modern converters suppressing these S-D artifacts that actually audibly affect sound quality...
Recording Engineer said:Ok, let’s take a look.
192 Input - 12k
192 Output - 50
ADAM S3A Input - 10k
Avalon U5 Output - 600
I don’t know. Seems pretty straight-forward. I certainly wouldn’t expect some drastic change in the low end due to great impedance mismatching myself. You?
mobdirt said:The convertors in the PARIS system sounded pretty good, like a hundred years ago, wonder who made those..
seva said:No need for blind testing of recorded files or measurements because you can hear it instantly.
bluebird said:And that's exactly what the career professional recording engineers and mastering engineers said, right before they got about half of they're guesses wrong when trying to pick out which converter was which.
bluebird said:This studio had three different rooms all equipped with hundreds of thousands of dollars of recording and listening equipment. Some of the best in the world.
Have you compared a MOTU 24io to converters you have heard?bluebird said:So I'm just really having a hard time with the descriptions of the differences you people are hearing in converter technology.
The OP mentioned a MOTU. Have you compared the Lavry to this technically or subjectively?bluebird said:I use Lavry Blue converters which are pretty old and make a good living doing so.
I agree. "Those" converters are incredible imobluebird said:The last thing I would update in my room if I had all the money in the world would be those converters and if I did, it would be purely for show.
Agreebluebird said:I suggest you do proper AB/X tests with proper equipment for yourselves before you throw around such strong opinions.
Yes. Throwing money away on converters is a bad thing imo if we're talking mouse farts differences. I would just hate for the MOTU compared to a Lavry or the others being compared here to be more of the elephant fart in his room . He may find that a mixer would be more appealing along with a higher end 2 , 8 or 16 channel converter if he A/Bs say the MOTU with even the older Mytek 8x96 or Rosetta 16Xs?bluebird said:I'm really not trying to be a jerk about this but these opinions can cause people like the original poster to spend a lot of hard earned money on something that wouldn't make a mouse farts worth of difference compared to buying a nice microphone or piece of outboard gear of the same monetary value.
bluebird said:There are a lot of opinions floating around out there but in my many years working in studios either recording or being a technician has anyone ever proven to me one converter "beat" another converter...
Just ask yourself how many great sounding albums were made on the old digidesign 888's. Or ADAT's remember those? Alanis Morissette Jagged Little Pill was recorded on ADAT...
Dude just get the MOTU...Concentrate on your gain staging with that console, the distortion and image problems you have are going to be a result of your ability as an engineer, not your converters.
