bluebird
No Scott, there wasn't any MOTU's in the test. I get your point. 8) But I would like the opinions being expressed here to have a little more procedural and testable weight behind them. After all music is subjective so I am not claiming to be the absolute truth in this matter.
That said, I did do AB/X tests maybe 9 or 10 years ago with two mastering engineers in a properly treated mastering room between a Digi003 and an Apogee PSX-100. The test was and analog source (tape machine) passively split to the A/D section of each converter, looped to the D/A section and monitored. The digi003 had to have pro tools running and a loop through setup. The apogee simply needed a cord from the A/D to the D/A section and could run stand alone. The DA out of each converter went into a relay based AB/X box to the monitoring section of the console.
Again no one could tell the difference between the two converters when guesses were tallied. I believe the MOTU box in question is at least of the same build quality as the digi003 so I don't have a problem recommending that box.
I just want to be clear on the test procedures so people can better make a decision about a purchase...I'm just trying to help. Not discredit anyone.
Definitely, and if your talking clipping, that is a whole other subject and I think the differences are a lot more apparent. That would not really be something for technically sound tests to determine. I have never done a converter clipping sound test and would suppose it would consist of lining up a song clipped by a bunch of different converters in your DAW and just using your ears to pick the one you like. No special AB/X testing required.
I would love to hear descriptions of clipped converters as that would be subjective, and poetry would be a good tool in communicating the results. ;D
seva said:Maybe it was common yesterday to clip an AD but in practice it is still done today.
