A mic that never was (a thought-experiment circuit for the RK-12 capsule)
If you swap BOTH pairs of wires, it doesn't change anything.
You are absolutely right, the circuit works in both versions.
But...
In many years of working with transformers I have noticed some rather subtle details.
If I connect the beginning of the primary coil 🔴 to the hot part of the audio signal, and the end of the primary coil to GND, the coil will behave as a kind of electromagnetic screen (especially the last layers of the winding) and we will have less hum. The secondary having low impedance will be less sensitive. That's why I chose the second variant of connecting the transformer.
Maybe that's why in many schemes we see the beginning of the coil marked, connected to the hot part of the signal.
    27.3 KB
I want to use a UTM0547 as OPT. I have used other ratios with a similat design in the past. J2 can be even be an BJT, but I'm just using parts I have laying around. Disregard R17, I forgot to pull it out, lol.
Many are of the opinion that J2 would be better off being a BJT.
But it's everyone's choice.
Is the schematic your design?
Thanks a lot @micolas
That's the DCDC circuit I am most familiar with and would like to use:
DC/DC consumes very little current. C1=330uF is huge. 47uF is enough.
You will need to feed the DC/DC through a resistor so that you give the Zener 9.1 just a few extra volts to effectively stabilize, not "stealing" more current from the audio circuit.
