bjosephs
So, several years ago I became enamored with the idea of analog summing and feverishly designed and built the devise I will show and describe below. As embarrassing as it is to say I never actually integrated it because I didn’t have much in the way of IO. I had planned to get some more converter channels but just didn’t. I did test it out with a few signals but aside from that the poor thing has sat in a rack for years.
Well stumbling on this forum and seeing other people’s summing projects shared I decided to dig it out and take some pictures. More importantly I pulled the trigger on a 24 out usb interface so I can give it a proper chance and do some mix comparisons.
The topology is simple: 4 virtual ground summing amps, two per channel with each summing the phase and anti phase signals of the balanced pair. Each channel is fed to a transformer for increased cool factor. There’s a DC servo in there that I don’t remember working all that well but we were in the mV range so I left it alone. It’s DC coupled aside from those two features.
I machined that back panel out of an aluminum block on a Bridgeport at work. I clearly took some shorcuts out mounting with the sticky squares and zip ties... probably planned on cleaning up my work after I was sure I made something worth while
Also I borrowed two of the 990s for my mic preamp project and threw in a couple of other discrete OAs from my collection.
