G
Guest
Guest
[quote author="Sonic"]Capacity of a cap with a membrane 25мм-80-90pF;
Cap with a membrane 32мм-120-135pF.
Data are resulted approximately as especially exact device at hand is not present.
Gaugings of capacity of a cap on LOMO MKE-271 have shown 35pF, but the resistor on shutter FET KP303 by face value 560M there is used.[/quote]
In such case differences for 1 Giga Ohm and 100 Mega Ohm will be inaudible. Since usually output from a first FET is taken from it's destination input capacitance will be much higher because of Miller effect; that means even lower impedance. Load of a capsule is mostly capacitive.
In my case ( http://www.groupdiy.com/index.php?topic=260576#260576 )a source of a FET is bootstaped by NFB while it's destination is loaded on a small dynamic resistance of B-E junction of PNP transistor so an effective capacitance is much less that means higher level of signal on a gate that leads to better S/N ratio. Again, it is an example how to kill many ducks by a single bullet.
Something similar happens in tube mics when a capsule is connected to a cathode follower so load capacitance is very low, but in such case resistances of resistors are more critical.
