Any reason you cannot run it off the same supply as the 312?Anyone have input/advice on this re: powering the VU/buffer circuit?
ian
That's what I'm asking, just wanted to confirm that it wouldnt cause any issues to run a track from the 500 card +-16v over to the buffer circuit.Any reason you cannot run it off the same supply as the 312?
ian
Nope! Just be sure to add PSU bypass caps from each rail of the buffer opamp, located close to the power pins of that chip. That's assuming a "pre-made" buffer doesn't already have the caps.That's what I'm asking, just wanted to confirm that it wouldnt cause any issues to run a track from the 500 card +-16v over to the buffer circuit.
Oay awesome thank you!! I think I'll probably just run traces to an empty pad so I can use wire to send the pwer and audio signal to the buffer circuit! And yeah, I assume the JLM has the bypass caps right? Looks to me like they might be C4 and C6 on the schematic?Nope! Just be sure to add PSU bypass caps from each rail of the buffer opamp, located close to the power pins of that chip. That's assuming a "pre-made" buffer doesn't already have the caps.
Bri
That would be greatly appreciated thank you!! I'm at the point in my electronics learning that I'm reading and comparing all the schematics I can! Feel free to PM me when you can! I can also share my email if it's easier for you to share that way.which I could share with you should you need some additional circuits to review
Yes, since you have room, a variable gain buffer would be easy to add. The JLM has extra stuff to handle the meters without diodes (unless you do select one of those) and make it functional if you don't have a bipolar (+/-) supply.One more question,, could I just build and layout the buffer circuit on my main 500 series card? I have a pretty large empty space as the 312 is relatively simple and think I could squeeze it on there pretty easily. In which case I wouldn't have to buy a buffer it'll just be self contained. Just not sure if the buffer being a completely independent PCB serves a purpose in isolating the circuit. I guess maybe the gnd connections on the buffer would need to be a separate gnd somehow?
Okay so I've found that there's "real" VU's and then tons of cheap "not real" vu's around these days. So If I got a cheap vu from say Aliexpress, I would certainly need a buffer circuit for it to work. However if I got something like the Sifam AL15 meter (linked is the data sheet) then I wouldn't need a buffer circuit and coould run this straight from the vio/gry output tx taps?
Sifam AL series datasheet
Variable gain buffer? Is that just referring to using a trimmer to dial in the gain of the opamp feeding the meter?a variable gain buffer would be easy to add
Are you referring to the actual JLM meter? (Here) Do I interpret that correctly where the only buffer I would need to add to my board then would be the op-amp to make up the gain needed? And not the circuit that's converting the AC to DC current to actually power the meter movement.The JLM has extra stuff to handle the meters without diodes
Do you have a link to what you're thinking of here? As i've linked above, I found a Sifam that fits my 500 series build but it's $67ish USD. Would love to find something that's maybe a bit cheaper that's still gonna perform well!One of the less expensive Sifams
My guess is the JLM meter and JLM buffer are intended as a combo. Somewhere I seem to have read the buffer may be available in different physical sizes to bolt onto the rear of various meters.Yeah I was thinking the same thing re: the JLM meter and it's price point! I just asked them directly on the forum so we'll see what the response is. Looking like the Sifam is gonna be my buy once cry once meter! Also realizing, I may need to go with the external/off board buffer circuit. Looks like I may actually have to get rid of my current empty space to make room for the VU meter. That's okay though. It'll probably be easier to mount the buffer directly to the meter anyway.
Cool I think I shall go with the Sifam then! Haven't been able to find any other companies that are making "real" VU meters and specifically talking about it so I like that Sifam is doing both of those things.The 'expensive' Sifam meters, (along with the other OLD makers of VU meters) are expensive because the magnetit pattern and the 'springs' define the ballistics and are difficult to make (or at least expensive to do so). A 'real' VU meter when hung across a 600 Ohm output introduces around 0.1% distortion of a 1khz signal when reading 0VU and worse as the level increases. Thus the need for the buffer amplifier. The AL19 (?) Sifam meters read accurately for a sinewave at 0VU for frequencies 20Hz up to 100KHz, actually below 20Hz but you have to average the needle position by eye as it is wiggling so much. Not bad for a magnet and springs!
Hi!Variable gain buffer? Is that just referring to using a trimmer to dial in the gain of the opamp feeding the meter?
I rememeber finding one of those in an old Japanese multimeter that croaked maybe 50 years ago. My lasting memory is that it had a funny smell.found a pic of the copper oxide VU rectifier do-dads, zero on evilbay>
[My lasting memory is that it had a funny smell] -- Might have been the fish.....I rememeber finding one of those in an old Japanese multimeter that croaked maybe 50 years ago. My lasting memory is that it had a funny smell.
