Tropicalista
New member
- Joined
- Mar 12, 2021
- Messages
- 3
Hello all,
After some time reading and researching this brilliant resource I’m posting my first post and looking for some advice.
I am working on a 1968 Neumann Recording Console that has a number of PV46sd line cards.
I have replaced the Electrolytic capacitors.
When on the bench they test good and have around 40 to 45db of gain. However I have two questions:
1. What does R27 do? It is a 5K trimmer. When I adjust it, the THD/Noise rises from 0.05% to 4% and it adjusts the volume by around 1db
2. All of the cards have 300 Ohm resistors at R11 & R12, but they all have slightly different output levels, ranging from 40db to 45db. Is this normal or is there
a possible component failure? Resistors test good with a multi meter. Trimmers test good.
Any help or suggestions would be greatly appreciated.
Will
Will
