Are you kidding? Have you read what i wrote in the original post, and the ones that follow? You actually have graphs that show what the cap does.I 'm wondering what this capacitor changes in the circuit and the sound of the microphone. What is its role in the circuit. I have read in different forum that this microphone P220 is very close to a U67 AI. i would like to understand what role does the 680pf play in the sound of this microphone. It's very delicate mod to do . I would like to have good information about the mod of the mic. the capsule looks like a Taskar. Should i change the capsule or adjut this capacitor to is right value? Thank you
I've made this mod to two P100s. I'd suggest, as a beginner, just change the cap for now. It's quick and fairly easy (although you should watch a video about desoldering smd components - that's probably the hardest part). Then you can listen to the Mic and decide if you want to change the capsule too as this will cost considerably more.Hello I have read again all the post it seems that 680pF is a good choice. Do you think i should change the original capsule?
680pF for what? The capacitor that rolls off the high end? That would give you something like a classic U87. Don't bother changing the original capsule, with the correct roll off you're getting something really close to a vintage U87. At that point the difference is probably just the acoustics of the body.Hello I have read again all the post it seems that 680pF is a good choice. Do you think i should change the original capsule?
They probably thought that one was worth changing because of the Mic Parts kit that sells you an upgrade for the input capacitor and a K67 that's almost certainly brighter than the stock one that Matt says is flatter than other K67s. I don't think he's ever recommended changing values of the capacitor in the feedback network because that would reveal that the RK67 isn't any better than other K67s."This capacitor" is a bit vague.
The subject of the capacitor at the beginning of this thread is part of the feedback network in the U87-like circuitry that most of the Perception uses.
This later got "confused" (or "confusing") when it seemed like you were asking about what looked like the input capacitor (between the capsule and JFET), several posts above. That, after the location of the capacitor that this thread is all about, was quite clearly shown right in the photo attached to the first post here.
