a2d
when turning the release pot it causes the meter to swing from +2 to -20?? has anyone had this problem??
when in GR mode or in bypass mode
mac said:I am interested in the relationship the Attack pot has on the compression circuit however. I used Lin 25K pots for attack in this unit and I noticed a difference in the behaviour between my unit and the "real thing" particularly when fully counterclockwise, and in slam mode.
Can someone help me to understand why the BOM states Lin or Log. Wouldnt this make a difference to the way the signal is presented to the GR circuitry?
mac said:Also, the other noticable difference is that often my gain settings when in GR mode make it hard to flick the "bypas" switch without the output jumping up several dB, and making me grab for the faders. Is there a way of pading the bypass so that it permanently reduces output by say 3 or 4 dB? Anyone else tackled this issue?
a2d said:when turning the release pot it causes the meter to swing from o to -20?? has anyone had this problem??
rev J
a2d said:ok I'll get a new one on Tuesday and see what happens
I really don't think its the pot,but who knows
when I turn the release CCW the needle goes to -20 and stays there,
and when I turn it CW it goes to +2 and stays there,???/
the needle seems to follow the position of the pot
Its an interesting one, my voltages seem to be ok +/- .5V
If you have gain 'reduction' in play and you bypass it you would expect the gain to go up (ie you are no longer reducing the gain with the FET), unless you had the makeup gain (output pot) set to bring the gain up to the bypassed signal level.
Chrome Heart said:Hello all
Im using mnats rev. J board and I have the Hairball meter with 12v lamp. I was going to just take the power from the "VU Lamp" feed on the PCB. Its showing 30+ volts on the meter from that point. I think I read something about a 220 OHM 5W power resistor to get the voltage in the neighborhood. Anyone using this setup? How is the lamp brightness?
I wish I could just go to Resistors R Us and get a few to check out.
gswan said:a2d said:ok I'll get a new one on Tuesday and see what happens
Sounds like a wiring error then. Your description does not sound like a step change so it's unlikely to be the pot. The pot should not change what is seen on the meter unless you are changing the voltage going to the gate of the FETs.
well I looked at the wiring again everything seem to be in its place, I'm really not sure
Interesting. I did not read that in the calibeation pdf. If it says to do that it certainly isnt clear to me.a2d said:for the tracking adjustment you don't change the level on the 1176, you turn up your source input (OSC)
