naa, it's not really that sensitive - the regular trimmer is workable
Looks like your VU meter does not have internal rectifier diodes.
You can add germanium or schottky diodes in a full bridge configuration across the meter terminals to fix this.
You will need to recalibrate the gain reduction metering section to compensate for the extra Vf across the diodes.
No i , didnt, could you explain me how to do it exactly, its my first time doing something like this. (Is there somewhere where it is already explained?)Did you take measurements of the gain of each amplifier stage? That will tell you which section has a problem. The first stage is around 30dB from memory and the second stage around 10dB.
Have a look at the troubleshooting page in my 1176 notes web pages:No i , didnt, could you explain me how to do it exactly, its my first time doing something like this. (Is there somewhere where it is already explained?)
By the way i found information about lowering the value of r33 and reversing the transformer, but the diagram was down, could someone share that mod again?
Although in reality I suppose that my unit has another problem that I should solve before doing that mod
Thanks a lot!Have a look at the troubleshooting page in my 1176 notes web pages:
https://axtsystems.com/axtsystems/proj_1176.php
I used WIMAs for mine, as I and many others do for most projects. Panasonic would be another high quality alternative.Hi,
anyone can recommend me some capacitors for the 1176 build? What brand or type? I see that some people mount Orange Drop's there, worth it?
2X 220n 10mm
3X 1u 15mm
Thanks.
I checked with the MM at the 7824 i have a constant 29.6 V. At -10V point there is a fluctuation in voltage, between -8.8 to -9.4, what should I check more? Thank you!Does your gain fluctuate as well?
If not, could be contamination around meter jfet
or, if your supply voltages fluctuate, this will impact meter reading: check if meter error correlates with +30V/-10V supply voltage drift
/Jakob E.
