ok I just did this and the buzzing is significantly less. However, there is still some hum and the VU meter still goes nuts when I turn the gain above 6.
I have seen this on my LA2 also. Probably ultrasonic oscillation. You might need to tweak your wiring a little. Get the meter to peg then start moving your wiring around with a chop stick. And make sure your front panel is grounded to the chassis if you yhave one of the hinged chassis.
I subbed in an 12AY7 for the AX7a first stage amplifier. Less gain which helped the oscillation, plus you are likely to find a 12AY7 that sounds better than your typical AX7a. More of a vintage sounding tube.
AWESOME!
you were right, it was oscillating frequencies. I found that the problem was the two wires for the limit/compress switch. It got rid of my squeals at higher gains.
The only problem is that there is sitll some hum, and i found when i put my finger close (not touching) the two posts for the limit/compress switch, the humming goes away. How do i fix this?
[quote author="Ad0lescnts"]
[/quote]
Make sure the metal of the switch is making good contact with your chassis. If the chassis is painted or anodized you may have to scape off a bit around the hole for the switch to do this.
Yeah CJ's awesome. I bugged the crap outta him when I was building my LA2. I owe the man a few dozen rounds of beer! :sam: :guinness:
So you were the guy!
:guinness: :razz:
FYI: keep your grid wires low, next to the chassis, and keep your B+ lines high. Also, try to make the B+ wires cross any grid wires at a 90 degree angle. jeeeez, giving away all my top secret stuff. oh well, getting old. time to download the hard drive!
awesome!
I looked into all those things and i got rid of all the buzzing. My only concern is that it does get pretty noisy when i turn the gain up all the way, but I was playing with it today and it seems i only really need to have the gain set at about 2 to get the volume where i need it running back into my interface. At this level there are no noise problems. Is this standard practice for these things?
Man this thing is awesome, it's amazing how many different sounds you can get just out of the one peak reduction knob!
Just a couple of solders before completion.. :grin:
Question:
Is C13 required if there will be no stereo couple for now?
I ask because I musta not ordered it..
Caine
