Rebuilt 4 of these mixers as a group, they had the buzz before, the buzz is unchanged after filter and coupling caps. The buzz meets Altec spec (which isn't worth much as described), but there are other examples of this mixer that do not buzz at all. You couldn't use these with a microphone unless it was a steady state loud source.
Disconnect B+ from V1/2 and remove the tubes, the buzz is still there with all mix pots off, master at normal level. Master off, buzz gone.
It appears the buzz can be isolated to the mix resistor / mix pot area. Disconnect all 5 mix resistors, the unit is totally quiet. Reconnect any one mix resistor to V3A input cap, buzz is back. Tried changing one mix resistor to metal film, just in case, no change. Leave one mix resistor connected to the cap, wire to pot disconnected, buzz is the same.
I experimented with the ground planes, test leads between different ground points to make sure nothing changed, since the case ground connections are all rivets. They've been tried in multiple environments too, and a lot of time verifying environmental noise, quietest case ground connections for listening, etc.
http://www.triodeel.com/al1567a.gif
