I have no idea whether this makes sense or not. I have seen this microphone once in real life, it has an imposing appearance.how about (2) RCA 5693 in place of the (2) EF12 in an RFT CM-7151 circuit along with a Cinemag CM-S217D transformer; that I’ve had all the parts for years and still haven’t gotten to?
I agree.I don't think I'd be able make myself plug a microphone into an AC outlet!
Every nerve would be screaming "wrong!" "wrong"!
Stanley Church was Chief Sound Engineer for the famed Metro-Goldwyn-Mayer Sound Department in the '50s. They bought a then-new Telefunken-badged Neumann U 47 to test and found that it was not good for soundstage applications; particularly dialog recording. The mic body generated too much noise, the electronics output was too hot for their equipment (which had been designed for low-output ribbon mics), and the mic pickup patterns weren't ideal. Plus, no one at MGM wanted to deal with obscure German tubes and transformers. However, they loved the sound qualities of the mic, as its presence peak and sensitivity were very useful for distant mic'ing.
Church ordered a bunch (less than 100 but more than 12, based on the number of known Church mics) of U 47 capsules from Neumann and set out to build his own mic body and electronics, utilizing a 6072 vacuum tube with a high-voltage circuit (though there are at least three circuit variations known). He focused on using off the shelf, U.S.- available parts for the electronics, in keeping with the Hollywood tradition of using non-exotic gear that was easily and quickly replaceable if it failed during a production day (when potentially millions of dollars of talent were on set).
Church's "new" mic was written up in the SMPTE Journal's 1956 "Year In Progress" roundup (indicating that it made its debut in 1955). The story told to me by my father, C. Robert Fine, and Bob Eberenz, his longtime associate, was that Church built the mics on his kitchen table, and built fewer than 100 of them.
The author's conclusion in the link, that the EF14 is a tube very similar to the VF14 (and therefore potentially a lower-cost alternative) is deficient in several aspects- a fact that is instantly audible when comparing by listening to both tubes in a (properly prepped) original U47. The EF14 sounds dynamically challenged- anemic and glassy, with accented high mids- among other reasons- frequency deviations due to a less than ideal impedance match with the GN8/BV8.
This is actually about American octal tubes, but I'd like to take this opportunity to ask you which solution is closest to the VF14?The author's conclusion in the link, that the EF14 is a tube very similar to the VF14 (and therefore potentially a lower-cost alternative) is deficient in several aspects- a fact that is instantly audible when comparing by listening to both tubes in a (properly prepped) original U47. The EF14 sounds dynamically challenged- anemic and glassy, with accented high mids- among other reasons- frequency deviations due to a less than ideal impedance match with the GN8/BV8.
Even when supplying these two tubes using the same ratio of filament under-heating, that still leaves a six-fold gap in actual heater supply voltage.
But there are two much larger reasons why no other metal jacketed tube, octagonal or not, will come close in performance to the VF14, no matter how much one adapts the circuitry around a substitute tube:
The filament arrangement (I posted a comparison picture showing two opened-up Telefunken octagonals a while back on GS), and most relevant, the cathode doping of the VF14 was never duplicated by any other tube.
That guy made the best possible empirical analysis of these tubes, provided measurements, and detailed explanation for everyone to decide.The author's conclusion in the link, that the EF14 is a tube very similar to the VF14 (and therefore potentially a lower-cost alternative) is deficient in several aspects- a fact that is instantly audible when comparing by listening to both tubes in a (properly prepped) original U47. The EF14 sounds dynamically challenged- anemic and glassy, with accented high mids- among other reasons- frequency deviations due to a less than ideal impedance match with the GN8/BV8.
Your biased claims throughout the years have damaged this field more than anything ever. Either lie, or delusion they come from your head. You are financially invested in the subject, and have never provided any informantion that would help anyone get closer to the goal. Contrary only discouragement, for all of us lacking golden ears or the original unobtainium you among others stash.I agree that, if you believe that listening to a microphone, then analyzing what you hear is overrated and should not be the relevant end point of any technical analysis and discussion about audio devices, then, by all means ignore my post and don't let it upset you.
I just don't think that static frequency measurements of a tube will give enough (any?) information about its dynamic behavior or response to complex waveforms, as encountered in music.
I tested all of the Telefunken Octagonals, and to my surprise found that I keep coming back to the replacement Neumann had designated, even if teh low end is lacking a bit: the 13CW4.This is actually about American octal tubes, but I'd like to take this opportunity to ask you which solution is closest to the VF14?
Sure, a real U47 has a VF14, but how close are the known replacement options in terms of sound? (even if that means making changes to the circuit or OT).
No, 13CW4 doesn't lack low end, however it does lack microphonic nature of the VF14. Which in purely technical sense makes it better. Maybe you can post the audio of your performed test?I tested all of the Telefunken Octagonals, and to my surprise found that I keep coming back to the replacement Neumann had designated, even if teh low end is lacking a bit: the 13CW4.
You seem to change your opinion depending on situation.I tested all of the Telefunken Octagonals, and to my surprise found that I keep coming back to the replacement Neumann had designated, even if teh low end is lacking a bit: the 13CW4.
Thanks for your feedback.I tested all of the Telefunken Octagonals, and to my surprise found that I keep coming back to the replacement Neumann had designated, even if teh low end is lacking a bit: the 13CW4.
