It’s supposed to, yes. But I’ve never had good results with the R156 method.Does this timmer affect initial mA/mV reading across R156? I've turned this trimmer 100 times
the bias trimmer adjusts the operating voltage
The Bias trimmer is the one that adjusts the measurement across R156 - or is supposed to. Mine seems to be barely changing although am getting together a better system for calibrating so will try again when ready.Does this timmer affect initial mA/mV reading across R156? I've turned this trimmer 100 times
I couldn't get my meter working on in or out when i tried but not sure if that's due to not having a correct stating point. Am currently building an oscillator pcb to help get a a guaranteed 0dBu signal so will get back to calibrating as soon as it done - just waiting on some components to arrive in the post.Ignored R156 and got calibrating. Meter In works but Meter Out is going nowhere. On this trimmer I did hear the "click" on the counter-clockwise rotation but meter isn't moving after many rotations.
Let me know if you get it working!I couldn't get my meter working on in or out when i tried but not sure if that's due to not having a correct stating point. Am currently building an oscillator pcb to help get a a guaranteed 0dBu signal so will get back to calibrating as soon as it done - just waiting on some components to arrive in the post.
Yes will reply here with all of my results. Still waiting on some parts arriving for a little oscillator PCB that i'm building thanks to ruffrecords on here but as soon as I get somewhere I'll report back on here. I've not had chance to try anything else since my previous efforts as been waiting to get my calibration set up straight before continuing. I'm also waiting on a PSU that is away for repair that I can use to measure the current on the bench outside of my 500 rack.Let me know if you get it working!
Yeah the calibration side of things did surprise me a bit as didn't see anywhere about calibration until downloading the build instructions once I'd purchased. Although it wouldn't have stopped me buying a kit to build I'd have definitely got the calibration stuff together before building as it's frustrating having spent the money on the kit plus the extender cards and not being able to use them right away. Especially as you can buy a very good compressor off the shelf for the price of the kit and extender cards such as an Elysia mpressor 500, ISG Audio Photon, TK Audio TKomp, etc.... I know you're getting a more expensive and unique unit once you're done with a 52F50 build but it's definitely not for everyone with the options available. I did mine to learn and I'm definitely doing that. Cool thing is the the next builds I do I'll be ready for the calibration as planning some 1073/1066 line pre's and EQ's when I can afford the next kits. Hopefully more news soon as my replacement parts are due to arrive tomorrow.I still think 500 series kits should have more consistent calibration methods. While most of us have ribbon cables, the double wides can be problematic….
glad you’re getting results. My stereo pair are rocking so hard. I’m really enjoying them. Using them on drum bus, vocals, bass and just dig a live piano session and they ripppped. Really cool compressor.
Any progress on your calibration?Yeah the calibration side of things did surprise me a bit as didn't see anywhere about calibration until downloading the build instructions once I'd purchased. Although it wouldn't have stopped me buying a kit to build I'd have definitely got the calibration stuff together before building as it's frustrating having spent the money on the kit plus the extender cards and not being able to use them right away. Especially as you can buy a very good compressor off the shelf for the price of the kit and extender cards such as an Elysia mpressor 500, ISG Audio Photon, TK Audio TKomp, etc.... I know you're getting a more expensive and unique unit once you're done with a 52F50 build but it's definitely not for everyone with the options available. I did mine to learn and I'm definitely doing that. Cool thing is the the next builds I do I'll be ready for the calibration as planning some 1073/1066 line pre's and EQ's when I can afford the next kits. Hopefully more news soon as my replacement parts are due to arrive tomorrow.
Not just yet but am collecting my power supply from repair tomorrow so will be able to carry on with it this weekend so will report back.Any progress on your calibration?
Continuity check between each pin is all you need to do which can be done in circuit. An easy check to see if that might be the problem. If you suspect the same fault as mine check the value of R156 as mine had gone faulty which I attribute to accidental shorting while looking away at the trimmer.How do you measure U1? Do you remove from circuit? This sounds like what happened with me.
If you don't have a short between any pins on U1 that's good as there shouldn't be. If you measure U1 for voltage do you get anything on the output pin?I'm not getting continuity off U1 from any of the terminals measured on the underside.
