dmp
Just want to say I'm enjoying the Matador / RuffRecords discussion on this.
Reading with interest.
That is not quite what I said and your logic is flawed.Matador said:So if I can paraphrase your argument correctly, you a) agree atmospheric CO2 concentration is increasing, yet b) the contribution of man is small, ergo, the increase must be due to something else? In order to be true, there must be some 'carbon sink' that is not keeping up with the additional input, albeit through some natural process. Which sink do you propose explains this?
ruffrecords said:The real question you seem to want to avoid is where does all the carbon come from and go to? The atmosphere contains about 780 Gtonne of of carbon of which about 90Gtonne is exchanged each year with the oceans, and about 120Gtonne with plants. Thus about 25% of atmospheric carbon is tuned over every year. I addition the oceans have about39,000 Gtonne of carbon dissolved in them, some of which is sequestered each year in the formation of sea floor limestone. 70 million Gtonne of carbon has accrued cumulatively over geological time and soils, vegetation and humus contain another 2300 Gtonne.
In amongst these figures, the 7.8Gtonne produced by humans annually is tiny. On estimate says it is a quarter of the error in the estimate (32Gtonne) of the estimated carbon dioxide production from all other sources.
Compared to the nearly 200 Gtonne that is exchanged annually with plants and the oceans it is tiny. Everyone seems to think we are the only source of CO2. There are several sources and sinks for CO2, nearly all of them much bigger than man made CO2. There is no reason to think any of the other sources are constant nor that any of the sinks are saturated. We understand so little about these big sinks and sources that any one of them could be causing the observed increase in atmospheric CO2. Any one of them could introduce a much bigger variation in atmospheric CO2 than human CO2 production. In fact the measured increase is only half the human CO2 output so at least 50% of it is being sunk somewhere.dmp said:So the human produced carbon that is converted from stored fossil fuel reserves into the atmosphere is 7.8Gtonne/year, or 78 Gtonne/decade, or 780 Gtonne/century? How is that tiny?
No, see above.When you report the atmospheric amount is currently 780 Gtonne.
The fossil fuel carbon is a stored term in the equation - putting this into a system that was in equilibrium can be destabilizing (even if the exchange rates to ocean/plants is large) would you disagree?
midwayfair said:You should cite your sources, Ian, particularly when you use a direct quote. You might also want to read Gerlach's own work addressing the statements you made:
The tobacco analogy to climate change is a particularly good one.
boji said:I found this interesting and wanted to share:
"Most systems to split water into its components -- hydrogen and oxygen -- require two catalysts, one to spur a reaction to separate the hydrogen and a second to produce oxygen. The new catalyst, made of iron and dinickel phosphides on commercially available nickel foam, performs both functions [at much lower current]."
https://www.sciencedaily.com/releases/2018/06/180629102602.htm
"Assuming the of conservation of energy is obeyed"
Back in 60s we used platinum catalysts for electrolysis (to break H2O + electricity into H2 and O2). (I recall my older brother making a fuel cell for his science fair project one year).boji said:I didn't assume i/o unity or above unity or anything. But let's say it takes 2A to typically hydrolyze water at a given output (not sure what you really need) and this 'discovery' allows it to equally produce this at 500mA, that means one wind turbine just turned into 4. Not an outright solution, but a step in the right direction. I also hear fusion is getting more efficient too with recent tests.
"EVs can remove pollution from dense population areas, but doesn't eliminate it, mainly just shifts it elsewhere. "
JohnRoberts said:Hydrogen fuel cells (or even direct combustion) like EVs can remove pollution from dense population areas, but doesn't eliminate it, mainly just shifts it elsewhere.
ruffrecords said:Assuming the of conservation of energy is obeyed, the energy input into the separation process must be at least equal to the energy obtained by recombining them (burning). Which begs the question where does the splitting energy come from?
A fuel cell vehicle uses hydrogen as fuel so the reaction is H2+O2 -> H2Oboji said:We couldn't scrub the water vehicle's exhaust with some fancy carbon catcher? (googlin' now).
dmp said:But the adoption of EV or fuel cell vehicles needs to go hand-in-hand with the adoption of renewable energy powerplants.
ruffrecords said:The other factor that is important for EV is the energy density of the energy cell (fuel cell or battery). I have no idea how fuel cells compare with current battery technology.
Another factor is weight. Steel cars are heavy. Plastics make them lighter but we don't want to be making more plastic. Aluminium is light also but needs inordinate amounts of energy to produce it.
I understand petroleum is still the most energy dense readily available fuel.
"A fuel cell vehicle uses hydrogen as fuel so the reaction is H2+O2 -> H2O"
They don't have an carbon as an emission, just water.
