Another diode bridge compressor
I think we discussed driving the diode ladders differentially above (example: "Siemens U273 [..] albeit with a different bridge arrangement" in #56 (and before).
So, for example, an expensive DRV134 preceded by scale-down buffer, or just an extra cheap transistor for inverting CV, I assume.
And sorry, I had actually posted in the wrong thread. Was referring to "Dual Compressor (diode varimu)" thread, with schematics showing a U3A -- for what I called 'balancing', probably erraneously -- to
"keep the DC voltage at U1 outputs at the same potential as the junction (of the diodes)".
I think that is a different approach (?), maybe even better, as it does not drive the diode ladders differentially, but 'evens out" CV potential directly at the diode/line junction, where it matters more ?
Thread is this:
https://groupdiy.com/threads/dual-compressor-diode-bridge-vari-mu.80978/#post-1042166
Schematics this:
http://ghr.fi/proaudio/dualcomp/dualcomp.pdf
Can the standalone diode bridge be retrofitted with this DC balancing ? Would different resistor values be needed ?
This question was meant for dual compressor but it also fits the new version of the diode comp.
https://ghr.fi/proaudio/diodecomp/64/32.pdf
If different amount of diodes were used, then it might be necessary to change R29/R31 and resistance of the pad before the diodes..
Installed the Monacor LTR-110 today and do not hear a difference either -- but also don't need +20 dBu output level when they start to spit THD.
So now it's one INA followed by a transformer on the output (while the diodecomp32 has two INA stages ).
Sounds cool!
Some kind of imaging thing happening. Can't quite put my finger on it...almost L/R swap ish in places?.Wearing headphones though..
Hi Scott,
Do you still have boards for the Dual Comp, Vari-Mu or Diode Bridge? I'd probably rather build the combined Dual Comp but I'm so excited about these designs that I'd tackle them individually if necessary.
I don't have access to PM yet but can respond if messaged :).
