Brian just emailed me to tell me that the Sowter 9820 has been added to his web site as a replacement for the API 2622. I had sent him the specs after taking one apart, and it looks like he already had a cross!
Also, he is doing the API output. I took down all the notes but misplaced the winding resistance. If anybody has a loose API output, ala Tommytones, etc, could you please measure the resistance of any coil? (they all ohm out the same due to quad winding structure).
I am going to send Brian all the details on the output so he can do one.
He also told me that he is working on the BA6a innerstage!
Here is some of the email:
I dissected the BA-6A interstage transformer and found a surprise
inside! It appears to be a Nickel core with a very small air gap.
Quite a surprising thing to do because the gap kills the permeability
and hence the inductance. This transformer sits in such a high
impedance circuit (Assuming the modified circuit with series resistors)
that it needs all the inductance you can get. Presumably they decided to
go for a high Nickel core for low distortion (good idea) but they put
the gap in it to avoid saturation if the dc gets unbalanced. They made
the gap with a very thin tape (a few microns) and have a very well
engineered brass clamp to hold it tight. This would be to get the
highest possible inducance. I should think this unit needs to be left
on all the time and adjusted for dc balance every time it is used.
Best regards
Brian Sowter
SOWTER AUDIO TRANSFORMERS (E A Sowter Ltd)
The Boatyard, Cullingham Road,IPSWICH, IP1 2EG England
Best regards
Brian Sowter
