[quote author="rodabod"]Kevin, I have to agree with Brian that this is a complex subject since it does depend partly on the conditions in which you set for the transformer.[/quote]
Understood... but the conditions "should" be known because it's supposed to be a 2622 replacement in the API circuit.
For a start, the transformer loading is not just the Zoebel network, but also the load of your line input (this could be say, 10K to 100K) which sits in parallel to your network.
When you say "Line input" what are you referring to: the "Loading resistor" or the amp itself?
If your talking about the Loading resistor... then I really get confused on this one. A lot of newer designs like the Cinemag, call for one... like 150k for the 1:10 ratio. Reflected impedance (to the mic) would be 1500.
Putting a "10k - 100k" parallel to the Zobel seems a bit low, no???
Also, the 2622 in the API pre ONLY had a ZOBEL... No Loading resistor... which is confusing.
I HAVE listened several times to these trannys (cinemag & Sowter) with & without the load resistor & there's a definite change to the "FEEL" of the pre. With the load, the "sound" is much "tighter" & without = it seems to breath more... seems more natural, open & resonant.
I guess this is were "Personal Taste" comes in.
In addition to this, there is a question of taste. Sometimes a little resonance towards the top-end can be nice. Sometimes not.
I'll tell you... there was definitely "Ringing" going on & it NEEDs something.
Kevin
I'm not sure how much ringing we are talking about here, and I'm not convinced that it definitely needs something. There are compromises which occur when you adjust a Zoebel network and it's a balancing act like many aspects of finding an optimum in electronics.
This is why I asked Brian... I'm not sure how much is too much but compared to other TX's I've testing, there was a LOT!!!
Like I said earlier - I tried a load resistor & it did NOTHING for the ring but the original API 312 Zobel DID = (5.1k & 220pf). But it seemed to roll off a little too much, so I changed the 220pf to 120pf & it seemed to be the best compromise.
For my last network setup for some Beyers, I had a compromise in allowing a small amount of ringing in order to extend response beyond 20KHz, and also had to allow around a 1dB rise around 16KHz in the process.
I did sweep the pre (with the Zobel of 120pf & 5.1k - NO LOAD Res) & it was dead flat from 20Hz - 22K. So I MAY be on the right track & it does sound very good... I've noticed (with ALL input TX's) that when you install a "Loading Resistor" the sound, especially the lower end, "Tightens up"
There may be a little too much resonance, the way I have them set up now, by not having SOME sort of Load Resistor added too... I'm giong to try this now!
I think you need to try a couple of preamps together with different setups (eg. no Zoebel and Zoebel set for minimum ring) and have a listen. A mic splitter would be a fair test source here in my opinion assuming your input trafos and opamps are the same.
Hope this helps.
Roddy[/quote]
Thank You for your help :thumb:
I'm going to do what you just said... listen. :green:
