B9A tube right angle mounts
COOL!!! Perhaps you are now on your way to 3D-printing your own versions of the ETTINGER "Threaded Mounting Cubes"!!!
And.....in order to help you get started on your way, here is a "10mm M3 Threaded Cube Standoff" as an -- STL -- file:
snip
Any comments? Ideas?? Suggestions???
Thank you very much for doing that. I have no idea if threads work in 3D printed plastic parts. I will print one of yours and let you know. I will try making one in PLA and one in PETG (which is apparently stronger than PLA).
I was wondering if a viable alternative would be to have a plain hole as you suggest but add a hexagonal cavity the shape and depth of an M3 nut on the four faces? I have seen this on the 3 DIN 41612 connectors I use to plug the PCB into the mixer backplane PCB.
snip
[add a hexagonal cavity the shape and depth of an M3 nut on the four faces?] -- Like this???.....
[on the four faces?] -- Aren't there -- SIX -- faces? That's what I count. Or, are there two-faces that don't get the hex's?
>> I certainly realize that this is all purely experimental in nature, but.....at least based upon the M3 hex-nut that I used for obtaining my dimensions, I had to enlarge the cube to -- 12mm -- due to the amount of material eaten away by the depth of the nut. In other words, should this become a "reality" for actual use, you would need to provide me with the actual dimensions of the cube itself, along with a datasheet of your metric hardware, so I could create an accurate 3D CAD-model based upon the "real" parts that you would be using. Meaning.....maybe your UK metric hardware is possibly smaller than my US metric hardware (outside dimensions, of course). I don't know.
Here's the datasheet information that I used to create the -- hex-extrusions -- in this 12mm M3 Mounting Block:
In order to allow some tolerance for easy insertion of the hex=nut, I added 0.020" (0.508mm) to both the width (now: 6.5mm) and the depth/height (now: 3.3mm). Of course, additional latitudes will also probably need to be taken into account due to the nature of the 3D-printing process and for the specific type(s) of material used. In other words.....>> GAME ON!!! <<
Now what???.....
  • 10mm M3 Threaded Cube Standoff - Version-3 - RENAME 2 STL.PDF
    59.8 KB
That will work fine for plain text .stl files but probably not for binary ones.
[but probably not for binary ones] -- To the actual files, they themselves don't much care what their extensions are called, as long as you don't try to import them and/or use them with the new extension names. I frequently will rename my binary-coded schematic and PCB-design files from their original program filename extensions (DSN for schematics and MAX for PCBs) and then rename them to "PDF" or something for security reasons. From there, I even ZIP everything up and then rename the ZIP file to "PDF". So, if someone is snooping around and copies my files and tries to either: A) Open them up as a PDF file, they'll get an error message stating that the file is corrupt, incompatible, unrecognized or something nasty. B) The same goes for the ZIP file as a PDF file. They can't unZIP the ZIP-file as long as its named as being a PDF file!!! They would have to KNOW that the PDF file is actually a ZIP-file and then rename it back to being a ZIP-file!!!
They don't realy, for small sizes. As you could see, dimensional tolerance is close to thread size, so you end up with either too large outer diameter or threads walking into each other.
PETG is definitely stronger that PLA, and clearly more heat resistant.
In addition PLA is supposed to self degrade (after all it's a biodegradable material) but I don't know what time scale it implies. I've never seen it properly documented..
I've done that when I designed brackets for affixing front panels to Eurocards.
See attached file.
  • board support euro ecrou 2.txt
    184.6 KB
This is a M3.5. M3 is 5.5mm face to face.
M3.5 is not a common size, you don't find them in hardware stores. Actually, it's not in the official ISO list.
In the part that I joined in post #166, I deliberately chose to make sizes as exact as possible, so the nuts are inserted with some force and stay there (check the geometry).
@MidnightArrakis you are, of course absolutely correct that there are 6 faces. I was thinking in terms of a particular application which only needs four.
Creating a cavity on all 6 faces does lose a lot of material. For absolute generality you need all six but you can never use more than three so it might make sense to have application specific ones with just one per hole.
Talking of application specific cubes, one I am particularly interested in is the one @abbey road d enfer posted above. This looks like a replica of the expensive die cast ones judging from your picture. One thing I do want to do is create a version of this that incorporates both top and bottom front panel mountings joined together by a thin piece 2.54mm thick that acts as a spacer between the PCB and the front panel.
https://www.srs-products.co.uk/eurorack-versirak-data-sheets/
If you look on page 19 of the above URL, at the top where is says Panel Kits you can see the pice I am interested in.
Which one did you go for?
Hey Ian - I think, like you, I have been waiting years for this technology to come to a more refined and affordable level. Especially after spending 5 grand on a laser last year.
After a bunch of mind-numbing research I went for an Elegoo Saturn 4 Ultra. It is an MSLA Machine, I may hate it; I sure hope not.
About half the ideas for its use were cosmetic items like Lighting lenses/bezels, meter bezels, and knobs etc (I have already researched/located inserts etc). The other half were more structural like this tube holder, rear mounts for gear we rack, and other little board holders and standoff type things etc. So it made making a decision more confusing. A local friend has a FDM type machine, so I figure for now I can just hit him up if I need anything like that - perhaps parts that need a fiber reinforced plastic etc. More likely I will end up owning both. Our humidity worried me too with the spool type FDM machines. Average humidity in the house is around 65% here on the coast of South Carolina. Storing those spools long term worried me. So for now I ordered 10 kilos of various resins to try, including some "structural" types, and a couple pounds of clear for some of my light pipe/LED holder ideas.
Amazon says my resins have shipped and arrive tomorrow, The printer still says arriving tomorrow, but has not shipped. In the meantime I have two grandkids excited and refusing to go home until the printer arrives - they love projects with "Grandpa Tony."
PS: I have a care package with transistors and some other goodies almost put together for you, things have just been chaotic.
Actually, when I designed the part, I couldn't find proper dimensions, so making two separate pieces made less constraints. If you have actual dimensions; I may be able to design the complete part.
I wish I did have actual dimensions. I had one given to me by SRS over 10 years ago. It is probably somewhere in the workshop but I have been unable to find it. I would not want to ask SRS for an stl file for obvious reasons so I plan to try to work it out from first principles and the DIN spec.
From what I've seen on the web, although the distance between fixing holes on the PCB is standardized at 88.9mm, there is no standard for the spacing of the front panel holes for fixing the bracket.
I'l try to make a dual version.
After a lot of searching I managed to find a STEP file for the Schroff version of the part. File attached (with the extension txt
rather than stp). I am printing one right now.
  • 60807211.txt
    77.6 KB
[This is a M3.5. M3 is 5.5mm face to face] -- OOPS!!!.....MY BAD!!! -- When I posted "Reply #164", it was 7:00 AM here and I had been up all night working on a variety of things. I had meant to download and insert an -- M3 X .5mm -- hex-nut and with my aging and blurry sleep-deprived eyes, I had inadvertently clicked on an -- M3.5mm -- hex-nut instead. Here is my updated data:
https://www.mcmaster.com/90591A121/
>> In the CAD-model shown below, I created the M3 hex-nut extrusion width as being -- 5.6mm -- in thinking that with the 3D printing process making the hole or "space" somewhat smaller than what the dimension actually is, that the ever-so-slightly larger actual dimension coupled with the 3D-printing process, will perhaps offer "just enough" of a snug-fit to have to slightly force-fit the hex-nut into the "insertion-space". In a somewhat similar fashion, having the extruded-depth be ever-so-slightly deeper than the actual depth of the nut itself, will then also hopefully allow the top of the nut to be flush with the outside surface of this Mounting Cube. You'll have to print one out, insert some M3 hex-nuts and then let me know.
[it might make sense to have application specific ones with just one per hole] -- Your wish becomes a reality!!! See below:
>> M3 Hex-Net Insertion Surface Sides:
>> M3 Machine-Screw Insertion Surface Sides:
>> Into "The Abyss" (Part-1).....
>> Into "The Abyss" (Part-2):
>> [I have also found a step file for the Schroff diecasting] -- For those members who may be wondering what it is that Ian is making reference to, here it is (from importing his attached -- STP -- file):
That's about it for now.
  • 12mm M3 Hex-Nut Thru-Hole Cube Standoff - Version-3B - RENAME 2 STL.PDF
    50.2 KB
