B9A tube right angle mounts
I am printing the test block right now whilst reading the various links about calibration. It says it should take a little over 55 mins.
ian
And the results are in.
The rectangular measurements are all very good. Even the 2 inch dimension is within 1 mil at the bottom and 3 mils at the top. All the shorter ones are within 1 mil. The only problem is with circles or hexagons on vertical faces where the top is lower than it should be. For example the top to bottom flat on the M3 nut hexagon should be 5.5mm but it is 5.33. The worst of the other two pairs is 5.47mm.
The problem is the initial unsupported span which seems to have drooped. I would not expect to see this where the holes/hexagons are laying in the XY plane.
Edit: In fact the holes in the top surface are all too small. The 0.24" for example is only 0.233". I don't have any imperial drill bits to try out so a future version with some metric holes like 3mm, 6mm and 10mm would be useful
Wow, dang close on the external measurements! I will make a metric one today after my coffee.
I made the cal. block on my A1 Mini, from PETG. The overall 1" x 2" size was about 0.012" undersize on each side, the 1/2" x 3/4" recess was spot-on, and the 1/8" and 1/4" holes were both a firm push fit for the appropriate pin gauge.
The 5.5mm hex was spot on except for the vertical measurement, due to slight drooping of the hot filament across the unsupported (top) span.
All pretty much what I expected and similar to my experience in making small mechanical parts on this machine w/ the same material.
(3D printed parts are not necessarily 'finished' as-is. You should expect sometimes to have to deburr/smooth edges, check and resize holes, etc, the same as for any other process.)
Happy New Year Ian and Everyone.
Here is the Metric Calibration Block for you. I put holes of exact size in 3, 4, 5, 6, 8, and 10mm along with matching depth for each hole on one axis, and through holes on another.
Additionally, on the lower flat, I included ANSI Specified Clearance holes and threaded holes for: M3 x .5, M4 x .7, M5 x .8, M6 x 1, and M8 x 1.25mm.
Next to those are 10mm wide through hole rectangles. the 5mm wide opening should match your 5mm remainder etc, and down to 4 and 3 and so on. That they match is most important. ID to OD.
The block is 75mm square and 50mm high at max. There are external measurements provided. I radiuses the bottom edges slightly to make removal from your platforms easier.
Same thing on the file as before - change the .txt file extension to .stl
I am going to replace them just as soon as my set of 6 multi-cap can replacement cans are done lol.
-T
  • Metric Calibration Block v3.txt
    2.9 MB
@13engrsapper thanks for that. I just started the print. It takes 3hrs 23mins. As it is nearly 11.30pm here it will finish early next year.
Happy New Year everybody
Oh man - Sorry, that is a long test print - perhaps I should try to shrink it up for next year :) I figured larger dimensions it might be easier to calculate errors.
Happy New Year!
The first print failed quite early on. The bottom layer appears not to have adhered properly. So I have changed the filament to an official Bambu one and tried again. So far it has reached layer 40 of 250 without incident. Fingers crossed!
ian
ian
I had two print failures yesterday - I got a bit cocky and switched resins without running a test and adjusting exposure.
ian
Do you use adhesive?
The most common causes for bad 1st layer are poor adhesion of build plate, bad bed temperature and Z offset out of whack.
The fact that it worked with a new filament may also indicate a filament that needs to be dried.
I do not
The bed temperature was OK according to Bambu Studio and it did its usual bed levelling before the print. I must admit I have gotten so used to it printing OK I often just set it off and forget about it. I only became aware that something was wrong when it started making funny noises.
I had been using that filament without problems for a few days including printing the smaller calibration block.
The only thing unusual about this print is that the first layer has a number of round and rectangular holes in it and some are quite near the edges .
Fortunately the second print completed without issue.
Dry filament is indeed very important, i regularly dry them with my oven.
Also, i store them in a "compactor" bag. These are originally aimed for storing clothes and blankets by sucking the air out with a vacuum cleaner. Makes a nice and inexpensive vacuum storage for filaments too. You can stuff some desicant packs in there for good measure.
