or add gain control upstream...?
I have trouble imagining a scenario were you would want to do that. Ideally you should just put a pot in front of your upstream amp. If you really only want 0-6dB (kinda limited) then just run the lower leg of your pot through a resistor of equal value. If it's inverting there's a standard circuit for level adjust there too. Post a schematic.Since this thread has a lot of folks smarter than me answering questions, here is one regarding THAT balanced out drivers. I have a circuit with a low impedance single ended output, perfect for using the 1646, however there is no output level control. Is it a horrible idea to use, for example, a balanced 600 ohm attenuator after the 1646? If that is a bad idea, how else might one incorporate a trim control (could even be 0-6dB) without adding another opamp?
Unlike a tube amp or an old school SS discrete circuit, the 1646 stays "desperately" clean till it hits the rails, where it just clips. No euphonic saturation.Sometimes the attenuator method is nice for driving the preamp hard and pulling levels back at the end.![]()
That is true, but in a properly designed system, in each link of the chain, the cut-off should be determined by a restricted number of well-defined 1st-order filters, which should put some order in the mess.While DC from a microphone would be of interest only to a meteorologist, extended low-frequency response is important to music. A typical signal chain for recording and reproduction may contain dozens of high-pass filters, mostly in the form of coupling capacitors - but also those present in the microphone and loudspeaker. Just as in low-pass filters, there is a phase shift in a high-pass filter that's related to its "order." Since most coupling capacitors form single-pole filters, their phase lead approaches 90° below their -3 dB "cutoff" frequency. So the phase response of the signal chain becomes that of a very high order high-pass filter.
No doubt it affects frequencies that are below cut-off, but I would think teh effect on frequencies above to be limited.And this phase shift affects signal frequencies at least a decade higher than the cutoff frequency of each stage.
Actually there are Bilchikov filters that are the equivalent of Bessel for high-pass. But I agree that in order to implement them, one has to have complete control of the whole signal chain, which is close to impossible.Unfortunately, there is no equivalent of a Bessel high-pass filter to bring linear phase response to all this.
I agree 100%, particularly because it also coincides with the need to reduce distortion due to capacitors (particularly lytics).The only way to undo most of this true phase distortion (or deviation from linear phase) is to move the -3 dB "corner" or "cutoff" frequency down ... way down!
I won't discuss the subject of phase audibility, because it's still debated, and there are equally knowledgable and respected opponents and proponents.Marshall Leach of Georgia Tech wrote a paper about this back in the 1980s. Therefore, sizing coupling capacitors for -3 dB at 0.5 Hz is not unreasonable! It's also why most Jensen transformers have low-frequency response down to well under 1 Hz. Of course, this phase distortion is cumulative - the longer the signal chain, the worse it becomes. Because kick-drums get much of their character from frequencies affected by this time domain distortion, long signal chains often reproduce kick-drums that sound nothing like the real-thing.
Couldn't it be attributed to the "barrel effect" (hump at resonance)? Most BR speakers are tuned with a slightly resonant alignment, because it "has more bass". Closed speakers are usually tined with a lower Q, because a larger Q implies a quite large box, which is not a good selling point.It's also why I've always preferred the sound of a woofer in a sealed box ("acoustic suspension") to one in a vented box.
I expect we are all in agreement that DC blocking poles need to be set "way down".While DC from a microphone would be of interest only to a meteorologist, extended low-frequency response is important to music. A typical signal chain for recording and reproduction may contain dozens of high-pass filters, mostly in the form of coupling capacitors - but also those present in the microphone and loudspeaker. Just as in low-pass filters, there is a phase shift in a high-pass filter that's related to its "order." Since most coupling capacitors form single-pole filters, their phase lead approaches 90° below their -3 dB "cutoff" frequency. So the phase response of the signal chain becomes that of a very high order high-pass filter. And this phase shift affects signal frequencies at least a decade higher than the cutoff frequency of each stage. Unfortunately, there is no equivalent of a Bessel high-pass filter to bring linear phase response to all this. The only way to undo most of this true phase distortion (or deviation from linear phase) is to move the -3 dB "corner" or "cutoff" frequency down ... way down!
The weakest link in reproducing natural drum sound is not the line level audio path response, that is arguably the easy part. Hint: LF loudspeaker response is increasingly difficult the lower we go. The energy content from bass/kick drums is lower than vocals but not as low as we might assume. For today's TMI about drums timpani appear to make notes lower than they actually do. The concave sealed back chamber forces a drumhead resonance series containing the first two overtones. The human brain connects the dots and fills in the missing (phantom) fundamental.Marshall Leach of Georgia Tech wrote a paper about this back in the 1980s. Therefore, sizing coupling capacitors for -3 dB at 0.5 Hz is not unreasonable! It's also why most Jensen transformers have low-frequency response down to well under 1 Hz. Of course, this phase distortion is cumulative - the longer the signal chain, the worse it becomes. Because kick-drums get much of their character from frequencies affected by this time domain distortion, long signal chains often reproduce kick-drums that sound nothing like the real-thing.
You are in good company. Back in the 70s I did some consulting work for Rudy Bozak (RIP). I asked him why he didn't consider adding a port to his classic and physically large "concert grand" loudspeaker. He said that classic music from a ported cabinet didn't sound natural to him. Since I was only there to consult about electronics I dropped the subject.It's also why I've always preferred the sound of a woofer in a sealed box ("acoustic suspension") to one in a vented box. The former is a 2nd-order high-pass filter while the latter is a 4th-order. The higher cutoff slope directly translates to increased time-domain distortion. This time-domain distortion at low frequencies is, for me at least, reason enough to use DC coupling when feasible and "over-sized" coupling capacitors (and Jensen or other "over-designed" transformers) in signal paths. And, obviously, the shortest possible signal paths will generally sound better in this regard.
I am inclined to say show me the money (data). NF has been widely attacked for as long as I can remember but I have never seen the proverbial smoking gun. That said I do not endorse pursuing vanishingly low distortion that is inaudible. I question the uber-op amps that can't be tested using conventional bench equipment without tricked up high noise gain. Surely that affects other op amp behaviors.I don't want to start on a rant about negative feedback itself because the subject gets really complex really quickly. But I think that extreme open-loop gains (with corresponding extreme feedback factors) to drive THD numbers down is generally a bad idea.
The inductor degeneration in his LTP is brilliant and I bet he made a lot of IC design engineers jealous. You can synthesize inductors onto an IC with caps and gain (gyrators), but impractical for use in a low noise IC input stage.Better IMHO to have an amplifier with high open loop linearity and keep the feedback factor reasonable - as Deane Jensen did when he designed the 990, which also uses inductors in the input stage emitters to stabilize HF response without paying the usual penalty in slew-rate or equivalent input noise.
Back when, a lot of people dismissed HF linearity as unimportant because the out of band HF distortion products didn't measure very bad in typical THD+N measurements. By the late 70s I rolled my own two-tone IMD rig (I modified a SMPTE analyzer to use 19kHz:20kHz). I found it extremely revealing for phono preamp design because the RIAA EQ LPF attenuated harmonic distortion components delivering better THD+N measurements than reality. The HF two-tone distortion product was actually boosted by the RIAA EQ, just like real world IMD from HF music content.The 990 design was also in keeping with the "spectral contamination" paper that Deane wrote with Gary Sokolich just before Deane died. Less spectral contamination happens in signal chains with higher linearity, lower feedback factors, and perhaps most important, bandwidth limiting. IMHO, it's very misguided to think that bandwidths over 50 kHz have any benefit. Well, I've already gotten deeper into this than I intended!
One common DC blocking pole encountered in typical audio paths are the Phantom voltage blocking caps. These are routinely tuned for low single digit cut offs. The luxury of making these another 10x larger is not very practical for mass market designs, and oversizing these particular caps can introduce other problems.
I do not mean overdriving the 1646, I was referring to driving the input stages hard (which could be tube, transistor, DOA, etc.) and then reducing the output. In any case, it is clear that the best practice is to have the level control before the balanced driver IC.Unlike a tube amp or an old school SS discrete circuit, the 1646 stays "desperately" clean till it hits the rails, where it just clips. No euphonic saturation.
I was referring specifically to a balanced 600 ohm attenuator, which should not. Someone mentioned they are expensive, but it doesn't have to be a Daven. Member AVDO sells modern balanced 600 ohm attenuators for under 10USD. More than a pot would cost, but it does more too!Adding an attenuator to the output of a 1646 pretty much negates it's balancing feature. The best way is to put the gain before the amp driving the 1646.
If you inquire within the professional audio engineers and producers, they will tell you one thing about my design of the Tonelux op-amp, is that it sounds more open at any gain. With the way I biased it, I increased it until it improved the distortion and when that leveled off, I stopped, then figured out a way to make that fixed. So the actual bias is what I would call a Class AAB design. The open loop gain is only 75dB, and like I said, the first pole is at 10KHz at open loop gain. The 990 is somewhere around 250-2KHz, and even with the low pass chokes on the input stage, when you run it at unity, is sounds a little pinched. Go to 6 or 12, and it sounds a lot better. I never understood why op-amp designers designed around unity gain stability, which effected the rest of the amp's characteristics so much. For me, I went for a design that was inherently stable without that kind of internal compensation. To do that, the gain had to be reasonable. Otherwise, it's like pressing the gas and the brakes at the same time. The TX op-amp still had distortion well below .01% worst case, and was usually around .005%.Yes we've been through that rant. Strangely a surprising number of the higher level folks here have expressed that high levels of feedback are bad in one way or another. Now you and FIX too?
For the record: Hogwash I say! There has been no reasonable explanation for high levels of feedback being bad other than proclamations about how it "sounds". Null testing is hard to argue with.
Define "open" and "pinched". Someone has to invent an openness meter and a pinch meter.it sounds more open at any gain.
Several have undertaken the issue, and came out with current feedback opamps.I never understood why op-amp designers designed around unity gain stability, which effected the rest of the amp's characteristics so much.
A question: What is a "purist" in this context?A question: Has anyone ever met a purist who has actually worked in the industry? I haven't...
The subject has been discussed times and times again. It has long been known that NFB substitutes an "infinite" series of harmonics to the "simple" open-loop distortion that is supposedly constituted of 2nd and 3rd. Particularly Peter J. Baxendall, in 1978, in his 5th chapter, where he invites the reader to analyse the issue under the light of shape instead of harmonic content.There has been no reasonable explanation for high levels of feedback being bad other than proclamations about how it "sounds". Null testing is hard to argue with.
The 48 Volt Phantom Menace Returns (1,480k) phantom menace paper
By Rosalfonso Bortoni and Wayne Kirkwood, THAT Corporation
AES Convention Paper 7909, 127th Convention, October, 2009
In 2001, Hebert and Thomas presented a paper at the 110th AES Convention which described the “phantom menace” phenomenon wherein microphone phantom power faults can damage audio input circuitry. This paper offers new information about the phantom menace fault mechanisms, analyzes common protection circuits, and introduces a new protection scheme that is more robust.
The 48 Volt Phantom Menace (153k) link to paper
By Gary K. Hebert and Frank Thomas, THAT Corporation
AES Convention Paper 5335, 110th Convention, May, 2001
The authors encountered anecdotal evidence suggesting that field failures of existing line driver and microphone preamplifier integrated circuits (ICs) were correlated with accidental connections between line outputs and microphone inputs with phantom power applied. Analysis showed that the most probable mechanism was large currents flowing as a result of rapid discharge of the high-valued ac-coupling capacitors. Commonly used protection schemes are measured, analyzed, and shown to be lacking. More robust schemes that address these shortcomings are presented. It is concluded that the small additional cost of these more robust protection schemes is likely outweighed by the reduction in field failures and their associated repair cost.
lots of good reference material on That corp website.
