Hi all - sorry for a "the basics" thread... I've been looking into scopes, have read many posts here and a lot online, particularly in the last 24 hours (most of which I've been awake thanks to my new daughter lol), and my head is spinning a little. I'm not sure if I'm missing terminology to better search forums and specs, but think it's time to ask some basics.
I'm keen to buy a scope... 50/50 education/practical use. To narrow down options let's just assume for now I'll go digital (I've read a heap, I get the benefits either way).
Uses:
*General scoping of Points in circuits for learning, including comparing to spice sims.
*line level scoping of i/o signals to assess circuit performance - e.g. I've designed a variable harmonic saturator - hoping to see i/o simultaneously on one screen.
*smaller signal traces like control voltages for a compressor, simultaneous with e.g. an input, output or both. How small?... e.g. a diode compressor (or any other small signal that an audio design might need)... so thinking: scope noise vs tiny signal might be a problem. Would like ability to scope DC only too, but I assume that's common?
Affordable 12 bit seems to be new. Something like the Rigol 802 or 804 has caught my eye... upper end of financials for though. Then there's the siglent sds1104x-e or keysight edux1052a... and there's usb options etc etc. I'd also like to future proof a bit... let's assume it's the only scope I buy for the foreseeable future, unless advice is "buy a cheap shitty one until you can afford an xyz".
Cost... has to be under AUD $1000, preferably under AUD $750 (roughly 500usd)... ideal would be much much cheaper... under AUD$500 (300usd) is my target and any decent scope in that range might be an insta-buy. But I degrees slightly... I'm particularly after understanding a few things first:
1) In lots of places it seems advice eventually shifts to "if you can afford 4 scopes, do that instead of two"... any thoughts? I'm imagining i/o and a control signal (3 traces) makes sense... maybe even two control signals at once (4 traces)... but do you guys use typically 2 or less on any range of project?? Is 4 a preferred solution for audio design, or is that more for other applications... I think I want 4 for the examples above... but not sure if I'm being over the top!? EDIT: Actually... I think I'll "need" 4... some of my hairbrained ideas have 3 control voltages ... still keen to hear general thoughts though as it might help me use a scope more effectively
2) so I might want to look at a sine wave through a circuit... sure... but what is the max display time called so i can look up specs in e.g the rigol 802/804.... could I zoom out and see a whole kick drum? Is that something a computer usb connection allows (e.g. long recordings of data)? Or is this just not how these digital scopes work?
3) does the rigol 802/804 generate sine waves etc... this called a "function generator" yeah?... and do i need one if it doesn't? E.g. could i use 24bit 44.1k audio... or a synthesiser oscillator? Or is a precision generator really more useful in audio design / calibration etc? If it is, I'd rather it was built in if possible...
4) for what I'm hoping to do (refer initial discussion above) am I even aiming for the right thing? Or is there a much much cheaper starting point that might get me 70-80% there while I see if 12 bit digital proces drop quickly throughout 2024?? E.g. I've just not looked into usb via computer... many post saying "no good for this and that" turned me off... but some of these comments might be out of date in late 2023.
Sorry for the long post. As always, any help would be greatly appreciated
Edits: grammar etc due to being stupidly tired lol
Uses:
