Try cleaning the track of the P&G with just a dry qtip. You'll see it becomes as clean as your description using alcohol. Including the tarnish on the silver lead outs.
On rare occasion it has gunk that has worked thru the overhead deflector and gotten onto the track, then just water and mild dilute detergent will take care of it. Often just water.
Slider bars are of course another thing, use whatever you want on them to get them shiny and clean. and don't forget to swab out the teflon guides. Then relube with one drop of TriFlow on the slide.
The track wiper is the most fragile part of the assembly and needs VERY CAREFUL attention. I wipe the mating surface off with acetone, but I have very stable hands. YMMV
The Caig products used to be the best in the world, but that changed many years ago when they changed the formulation. Now its ok, but the spray bottle is a POS. If you must use it, please use it indirectly with something like a qtip soaked in it, or squirt it into a syringe. The overspray their dispenser creates leads to dust and dirt collection in your equipment, not good.
I have been using Elecrolubes EML-200 for a number of years on switches and pots with excellent results and good control of the application. The good news in the US is that it is now available in small lots from Newark and some other distributor (look at the Electrolube website for distributors). I used to have to buy it by the case.
If you use an ultrasonic bath, you will need to re-lubricate all the switches and pots as it removes the basic mechanical lube from the assembly, not good. For general cleaning its better to put it in the sink and use a low pressure (ie normal) flow of hot water over everything. I usually use a spray on citrus cleaner for general purpose cleaning in that situation (orange blast, orange whatever, etc) and the grime comes rolling off, without penetrating the switch bearing surfaces. Then a good hot air dry til ALL the water is gone. I use a heat exchanger off my hot water heating system (because I have it) Lots of air, lots of heat gets it dry in no time.
some useful ideas that have worked for me.
Alan
