boji
my inclination.. perhaps USB drive and paper backup JIC
+1 Offload the wallet onto a thumbdrive. Stick it in a waterproof, electrostatic bag and forget about it.
Fatal last words, hahaJohnRoberts said:I am still skeptical but the technical analysis looks promising in the near term (years)...
include redundancy (a copy stored in a separate place).boji said:+1 Offload the wallet onto a thumbdrive. Stick it in a waterproof, electrostatic bag and forget about it.
I have been buying common stocks since the 60s, more and less at different stages of my life.Script said:A bit late already?
I have been following bitcoin from a distance for years. It has been a casino bet for years and probably still is, with the extra risk of not having a secure trading vehicle (like gold ETF).I had predicted in Jan 2018(?) that it would probably go down from 8000 to 5000. It plunged even further. Shortly after that, back then, would have been a good time to buy.
Agreed, it does not have a cash flow like other investments, but statistical analysis is the investor's fortune teller, imo.JohnRoberts said:Since there is no fundamental proposition to vet, all we have is statistical analysis to gauge market price interest.
The halving is about the mining reward - does not reduce the amount in circulation. The growth of the supply slows.The BITCOIN touts talk up the next (halvening?) when amount in circulation declines or gets harder to grow new. This is part of the engineering to boost scarcity and increase price.
Do not buy BITCOIN based on my blather, but if you do a small position should limit the pain from total collapse, and if it goes hyperbolic will still pay off... I advise more old school common stocks for long term investment but the current bull market is arguably long in the tooth with slowing earnings growth and low inflation expectations.
I sure can't... But statistical analysis is thousands of years old. While it cannot predict future prices specifically it can estimate probability of size and direction of future moves. Up this much, or down this much. Logically averaged over multiple positions with bias toward buys that have projected larger upside than downside can be profitable...dmp said:Agreed, it does not have a cash flow like other investments, but statistical analysis is the investor's fortune teller, imo.
Bitcoin is a asset that may become more valuable or may become worthless. Nobody can see the future.
An investment in a brand and customer base. I do not believe in netflix or use it, but many do.It certainly doesn't have negative cashflow for the past 8 years like netflix,
Some touts are enthusiastic about uber as a new way to do business... I am not so sure.Nor did it lose a billion dollars last year like uber.
indeed fake meat is real trend, but the stock appears to be a fad without significant barriers to competition. Danger Will Robinson.Nor is it a fake meat company with no barriers to competition valued higher than many established, profitable companies.
;D
LIke I said, if you must only buy a tiny amount you can afford to lose. Block chain is the real deal, but BITCOIN is still a casino bet.Anyone considering buying bitcoin should just read the white paper and decide if you consider it a technology with value.
https://bitcoin.org/bitcoin.pdf
If you think blockchain is the key technology and not bitcoin, then you probably shouldn't buy it.
If you think other cryptocurrencies will create inflation, then you probably shouldn't buy it.
If you think government regulation is an existential threat, then you probably shouldn't buy it.
If you are only buying due to FOMO, then you probably shouldn't buy it.
This is well inspected and indeed we are late in this cycle when things should be slowing. Remarkable that the market has held up as well as it has, as long as it has.As this business cycle slows down, the key question for stocks is will there be an earnings recession.
How BITCOIN performs in any circumstance is a big question. :How bitcoin performs in a market downturn / economic recession is a big question.
While you wouldn't know it from the news heavily biased on all thing political, there is plenty of uncertainty in the world driving international investors to buy safer US securities. Bonds are down around 2% because of all that buying ..... that sucks...Usually as fear takes over investors flee to cash.
I have no idea who that is... Technical analysis is thousands of years old and there are many books on the subject...john12ax7 said:Speaking of technical analysis, anyone with insights or thoughts on the type of techniques Jim Simons uses?
Script said:Self-fulfiling prophecies for sure and clearly not to be trusted cos utterly detached from real economic development
dmp said:If you think blockchain is the key technology and not bitcoin, then you probably shouldn't buy it.
JohnRoberts said:letting my fingers do the walking I found this "the Medallion Fund, which used an improved and expanded form of Leonard Baum's mathematical models, improved by algebraist James Ax, to explore correlations from which they could profit. "
I am not a big fan of quants, or hedge funds but will credit medallion/renaissance with filing a patent on a technique to thwart high frequency traders who apparently bother them too... The m/r approach is to use precise atomic clocks to synchronize trades across multiple exchanges to prevent front running or other ways to use a speed advantage to skim profits from trade data.john12ax7 said:That's a good start in the right direction. The medallion fund returns about 40% per year, wow. But it's not open to outsiders and they are a bit secretive with the strategies.
Too bad we can't go back in time and make trades based on what we know now. ;D ;D Gold appears to be basing and technically could break out higher, but gold is a hedge against currency inflation which seem stuck below 2%, not a real investment. At some point the tight labor market should significantly move up wages, and probably is already in the margins. My gold position is maybe 3% of my portfolio so not crazy to increase that from here (I'm old).Script said:Could have averaged down on the gold position instead... But somewhat risky too, considering its development over the last couple of years.
